Matching Center Mark style in dimensions
Here in the picture I have a Radius dimension and a Diameter dimension. Is there any way to make the Center Mark circled in red be the same style used for the Center Mark depicted in blue? I'm looking for a method of doing this without changing either the Radius dimension to a Diameter or vice versa.
You must be using two different dimension style to get that result.
Check these by highlighting the center mark one at a time and look at Dim Style Control.
Open dimensions style manager ( Press D then return/space)
Go to symbols & arrows.
Change center mark size.
  • 2 months later...
kspabo,
As gazza_au said, you must be using different dimension styles; if it is a focused issue, you can match the properties with the command “MA”, then selecting the object with the style that you want to apply and finally selecting the object or objects that you want to change. If it is a general issue, you must change the Dim Style as gazza_au explained on his reply.
Let us know if this helps you.
