craigmcadams Posted May 27, 2015 Share Posted May 27, 2015 I used to be able to draft in all three planes without needing to make any UCS adjustments. Now I can only draft on the XY plane. If I want to begin a pline an I snap to a point on my existing model that is above or below an elevation of zero, the line snaps to that point but on the zero XY plane, I cannot draw above or below that point. This was never an issue for me before, and I think I only started to have this issue when I loaded SP2. Is there a variable I can toggle to be able to draw in all planes at all elevations? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 27, 2015 Share Posted May 27, 2015 It sounds like maybe you need to adjust your OSNAPZ variable. Quote Link to comment Share on other sites More sharing options...
zaphod Posted May 27, 2015 Share Posted May 27, 2015 is your dynamic UCS (F6 on my machine) on? do you have 1 in that version? Quote Link to comment Share on other sites More sharing options...
