rafaelrafa10 Posted May 27, 2015 Share Posted May 27, 2015 Hello. I need to create a iso.dwg file in order to project some ortographic views directly from Autocad Inventor. The problem is I cant rotate the assembly to get that... It is always projected like an isometric view. Can anyone knows how can i do that? Quote Link to comment Share on other sites More sharing options...
gazza_au Posted May 28, 2015 Share Posted May 28, 2015 Have a look here. Quote Link to comment Share on other sites More sharing options...
Lazer Posted August 25, 2015 Share Posted August 25, 2015 Your view cube is not on the correct orientation to that visible plane, I would reset that first. In the drawing view make sure you select a true view of the model. Quote Link to comment Share on other sites More sharing options...
