PASTECLIP Lag (Cycling through other open drawings?)...
lamensterms
Hi guys,
I'm getting some lag when pasting from the clipboard (see GIF below).
This doesn't happen all the time, but it is recurring. It seems to me (base on the modemacro display) that ACAD is cycling through each open drawing when pasting from the clipboard.
In this example, I had copied a line to the clipboard and pasted it back into the same drawing. You can see a lag for a couple of seconds, as well as some strange activity in the modemacro area.
I've checked out this link... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Copy-and-paste-in-AutoCAD-hangs-for-a-long-time-or-fails-to-work.html
The solution at this time seems to be an ACAD restart. But the issue will eventually return. Anyone know what might be causing this? Or how I can avoid it?
Thanks for any help.
