dumfatnhappy Posted May 28, 2015 Share Posted May 28, 2015 I have this thing that I created in Acad but can not get a flat version of it (except 'Flatten') but poor quality. the helical blades (to the left) is the culprit.. if I delete it everything works. but if it's anywhere in the dwg..... fagetaboutit.....! sectionplane or flatshot draws a blank (pun intended btw) Anyone have experience with this? spiral.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 28, 2015 Share Posted May 28, 2015 (edited) Created with the BaseView command. Hidden lines layer was frozen. I tried using Flatshot twice under two different conditions but it failed to create any 2D geometry. I have no idea why that is. Third time was the charm...well sort of. I got Flatshot to work by separating the helix and a couple of the vanes(?) from the original 3D model. It worked on the separate parts yet failed to work on the model as a whole. Strange. Fourth, and last try using Flatshot. Removed the helix and the result was this... I give up. Edited May 28, 2015 by ReMark Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 29, 2015 Share Posted May 29, 2015 DFnH: What's up? Were you finally able to resolve your issue with Flatshot? Quote Link to comment Share on other sites More sharing options...
dumfatnhappy Posted June 10, 2015 Author Share Posted June 10, 2015 Hey man, sort of. I did a flatten on the vanes which worked ok. Now I have to erase the vanes, do a flatshot (which works perfect) then doo an 'oops' to bring my vanes back and use the flattened ones for my plan & sections, etc. Meanwhile my model stays in tact. just lyin, cheatin n stealin baby.... Quote Link to comment Share on other sites More sharing options...
