Sengna Posted May 28, 2015 Share Posted May 28, 2015 Is there a way that i can set the units on autocad that work both way decimal and architectural: ex: i set the units type as decimal I want to offset a line 5 inch i do: Offset then specify offset distance---- type 5--enter then it will offset. But if i want to offset that line for 1feet, i do Offset then specify offset distance---- type 1 '--enter (Requires numeric distance, two points, or option keyword.)?? it won't offset for me. Is this possible in Autocad 2015?? thanks Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 29, 2015 Share Posted May 29, 2015 (edited) Sounds like you want to have your cake and eat it too. I don't believe you will be able to do that, as the decimal based dimension style won't understand the foot sign. But in this instance typing 12 is the same number of keystrokes and easier, because they are right next to each other. Edited May 29, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 29, 2015 Share Posted May 29, 2015 I am set on Architectural units, and the program will accept 28, 28" 2'-4", and 2.33' all for the same distance. But then again, I am not typing a space between my digits and the ' at the end. Your command line appears to have a space between the 2 and the' No spaces are allowed. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 29, 2015 Share Posted May 29, 2015 (edited) I am set on Architectural units, and the program will accept 28, 28" 2'-4", and 2.33' all for the same distance. But then again, I am not typing a space between my digits and the ' at the end. Your command line appears to have a space between the 2 and the' No spaces are allowed. Good point Dana, thank God I rarely have to use Imperial, what a pain in the butt! It does appear that if the UNITS are Decimal, it won't work, but as you describe does, with UNITS set to Architectural. The screenshot and commandline history were created with units set to Architectural, per your suggestion, no problem. Edited May 29, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 29, 2015 Share Posted May 29, 2015 In my experience, decimal units is used to indicate feet, typing 1 without the foot mark gives you 1' with the foot mark being understood. Setting units to architectural does exactly as you described. If you type in 5 (no symbol), gives you 5 inches. Typing 1' is recognized as such. Quote Link to comment Share on other sites More sharing options...
zaphod Posted May 29, 2015 Share Posted May 29, 2015 you could use a macro like this ^C^C^C_o;(cvunit;\;"FEET""INCHES") Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 30, 2015 Share Posted May 30, 2015 Thinking out loud you may be able to do a transparent command at the input request (f 3.5) this is 3 feet 5" 3.6, the other way old fashioned is using screen menu's you can have a label 3" but the button gives 0.25 as a response. Depending on what it is your doing you may want to do a lisp front end so you can enter just 3.5 = 3" 5" as an example ddd.mmss for bearings enter 123.4530 123 deg's 45 minutes 30 seconds. Much easier than 123d45'30" Quote Link to comment Share on other sites More sharing options...
Sengna Posted June 1, 2015 Author Share Posted June 1, 2015 Sounds like you want to have your cake and eat it too. I don't believe you will be able to do that, as the decimal based dimension style won't understand the foot sign. But in this instance typing 12 is the same number of keystrokes and easier, because they are right next to each other. That's what i thought, i would be nice if Autocad is able to do this feature. Thank you anyway Quote Link to comment Share on other sites More sharing options...
guitarguy1685 Posted June 1, 2015 Share Posted June 1, 2015 why not use engineering units? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 1, 2015 Share Posted June 1, 2015 Setting units to architectural does exactly as you described. If you type in 5 (no symbol), gives you 5 inches. Typing 1' is recognized as such. You probably missed this the first time. Quote Link to comment Share on other sites More sharing options...
