+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Forum Newbie
    Computer Details
    NRotaryTech's Computer Details
    Operating System:
    Windows 10
    Computer:
    Samsung Notebook
    Using
    AutoCAD 2017
    Join Date
    Sep 2016
    Posts
    1
    Default Help student create an Arc on Ellipse to Ogee Curve.
    Hello,
    I'm a student taking a CAD class.
    Using AutoCAD 2017.
    The drawing I'm working on is basically of a wrench. An "S" curve wrench.
    I used "Ellipses" to make the ends of the wrench and an "Ogee curve" to make the body of the wrench.
    I need to make Arcs where the Ellipses meet the Ogee curve(s). Arcs with a radius of .25.
    I don't know how to do this other than make R.25 circles out in space, then move them into place via eyeball, which isn't accurate.
    If anyone can describe other ways to do this, I'd appreciate it.
    Some more info:
    The ellipses diameters: One is 1.25 minor and 1.63 major. The other is 1.38 minor 1.75 major.
    Distance between Ellipses (width), from center to center is 4.12
    Distance between Ellipses (height), from center to center is 2.00
    The Ellipses are vertical.
    Scale is 1:1 on a sheet size of 11 x 8 1/2 inches.
  2. #2
    Forum Deity steven-g's Avatar
    Computer Details
    steven-g's Computer Details
    Operating System:
    Win 7
    Discipline
    Construction
    steven-g's Discipline Details
    Occupation
    Draughtsman
    Discipline
    Construction
    Details
    I work in the estimating department of a large building contractor.
    Using
    AutoCAD 2018
    Join Date
    May 2013
    Location
    An Englishman in Belgium
    Posts
    2,165
    Default
    I have to be honest, I can't picture in my mind what you mean, but 2 alternative methods for creating curves at junctions of other geometry that I can think of, would either be the fillet command with a radius of .25 or use the offset command with a distance of .25 on the ellipse and the curve and this should give you the center point for the circle. If those don't help maybe you could post a dwg or an image to show what you are wanting to do.
  3. #3
    Forum Newbie
    Discipline
    Mechanical
    Using
    Inventor 2016
    Join Date
    Jan 2017
    Posts
    7
    Default
    Remember this trouble.
    Create the arc using "tangent, tangent radius" to define position and size.
  4. #4
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,715
    Default
    Yeah the famous for over 30 years the "Fillet" command. One day Autodesk will fix it.
Similar Threads
  1. Replies: 22
    Last Post: 25th Sep 2015, 01:08 pm
  2. A different way to create an ellipse or oval
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 28th Oct 2012, 08:20 pm
  3. How To Create Ellipse In Autocad?
    By huygen in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2012, 03:15 pm
  4. Help w/ Ogee edge
    By controversia in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th May 2008, 04:14 am
  5. ogee curve
    By David Wilsher in forum AutoCAD Beginners' Area
    Last Post: 25th Oct 2004, 06:31 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
