ivanveliki Posted June 5, 2015 Share Posted June 5, 2015 I have a strange mouse problem. I bought a new laptop Toshiba Satellite C50. I am using AutoCAD mostly for 2D drawings. Every time I use command aliases I have to wait 1-2 sec so that I can select anything with the mouse (points, objects, etc.). The commands start without any delay (as I can see the prompts), the mouse movement is OK, there is no lag in cursor movement, but I cannot select anything within these 1-2 sec. Autocad does not respond to mouse clicking within these 1-2 seconds. The strange thing is that if I start a command using the buttons from the ribbons, there is no delay at all and everything is OK. I am used to command aliases and this problem significantly reduces my productivity and drives my crazy. I have tried different versions of AutoCad, but the problem is the same in each version. I will appreciate any suggestions. Intel® Celeron® N2820 processor with Intel® Burst Technology 2.0 (2.4 GHz, 1 MB cache) 4 GB DDR3L 1600 MHz (low voltage) Intel HD Graphics (Bay Trail) up to 1,792 MB shared memory from 4 GB system memory installed (with a 64-bit Windows® operating system) OS: Windows 7 Ultimate 64bit AutoCAD 2012 64bit Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 5, 2015 Share Posted June 5, 2015 Did you try swapping out the mouse for another one? A simple, easy and quick test that would reveal if the problem is actually mouse related. Quote Link to comment Share on other sites More sharing options...
ivanveliki Posted June 5, 2015 Author Share Posted June 5, 2015 yes, I tried different mouses (wired, wireless), but no change at all. Also all drivers are up to date. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 5, 2015 Share Posted June 5, 2015 Maybe the lag is a result of a faulty keyboard. Quote Link to comment Share on other sites More sharing options...
ivanveliki Posted June 5, 2015 Author Share Posted June 5, 2015 I don't experience problems with keyboard in other programs. When I enter an alias, i.e. "l" for line command, Autocad responds immediately and prompts for the first point, but does not respond to mouse clicking for about 1-2 seconds. After I wait 1-2 seconds and select the first point, I have to wait another 1-2 seconds to be able to select the second point (no key pressing needed). This happens also each time I press "enter" or "space" to continue command's procedures. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 5, 2015 Share Posted June 5, 2015 If both the keyboard and mouse work in all other Windows programs then the fault lies with AutoCAD. It can't be a bug otherwise we would see thousands of people complaining about the problem so that would seem to mean the problem is related to your system. Maybe a REPAIR of the installation is in order. Quote Link to comment Share on other sites More sharing options...
