Trouble removing scalop from axe face
northernmach
I have been using Inventor since about 2006 and currently on version 2010. Most of what I do is very simple very rarly having a need to get into 3D sketching and surfaces.
I currently am having an issue with simply trying to remove a scallop area off an axe blade that I am modifying. Attached is the file which has a boundry patch that I am just trying to extrude up through the original face cutting away the material thus leaving a scallop.
Can someone explain a process for doing this. I have tried to use thicken/offset and get an error message when trying and am not familiar enough with tools to try a different way.
Thanks,
Chad
northern_straight.ipt
