motee-z Posted June 7, 2015 Share Posted June 7, 2015 I am trying to set angle to polyline vertex using pedit then edit - tangent the temp arrow drawn to show angle direction but nothing changed any reason for that please help i am using autocad 2013 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 8, 2015 Share Posted June 8, 2015 Could you post a graphic, or the .dwg? Quote Link to comment Share on other sites More sharing options...
eldon Posted June 8, 2015 Share Posted June 8, 2015 Are you de-curving the polyline before you set the Tangent at a vertex? Anyway, you have to Fit the curve to make this tangent effective. Quote Link to comment Share on other sites More sharing options...
motee-z Posted June 8, 2015 Author Share Posted June 8, 2015 may i was not clear the polyline i used have a width ex 5 units so i want to set angle to start point vertex instead of perpendicular angle Quote Link to comment Share on other sites More sharing options...
eldon Posted June 8, 2015 Share Posted June 8, 2015 Your words alone do not describe the problem. Let us all understand when you post a picture of what you want to do, and post the drawing (or the essential part of it) that you are using. Quote Link to comment Share on other sites More sharing options...
motee-z Posted June 8, 2015 Author Share Posted June 8, 2015 here is a shot picture Quote Link to comment Share on other sites More sharing options...
RobDraw Posted June 8, 2015 Share Posted June 8, 2015 That probably isn't possible with a polyline. I think you have to "cap" the end of the polyline with another object. Quote Link to comment Share on other sites More sharing options...
eldon Posted June 8, 2015 Share Posted June 8, 2015 You are not using the Pedit command properly. The Tangent option applies to curves. Your requirement has nothing to do with curves. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 8, 2015 Share Posted June 8, 2015 The only way to do this is to use something like creating a pline pattern and a hatch. Its complex and would be user specific in this case parallel to a line. I have code but I can not post for copyrite reasons. Do two offsets of the pline add a offset to be trim line trim at plines and line close other end then hatch Quote Link to comment Share on other sites More sharing options...
