Help with a Leemac routine:
woodman78
You mean this one?
(defun c:offout ( / e s )
   (if (setq s (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&=") (70 . 1))))
       (vl-catch-all-apply 'vla-offset
           (list (vlax-ename->vla-object (setq e (ssname s 0)))
               (if
                   (LM:listclockwise-p
                       (mapcar 'cdr
                           (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) (entget e))
                   -0.75
                    0.75
;; List Clockwise-p  -  Lee Mac
;; Returns T if the point list is clockwise oriented
(defun LM:ListClockwise-p ( lst )
   (minusp
       (apply '+
           (mapcar
               (function
                   (lambda ( a b )
                       (- (* (car b) (cadr a)) (* (car a) (cadr b)))
               lst (cons (last lst) lst)
(vl-load-com) (princ)
It ran for me. Although, not very dynamic for Lee's standards.
I came across this piece of code from LeeMac but when I run it and select a polyline nothing happens. Can anyone tell me why?
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/polyline-offset-trim-and-erase/td-p/4503753
The program offsets a selected closed 4-vertex polyline to the outside by 0.75 units - therefore, in your case, either the polyline you have selected is smaller than this offset distance, or large enough that the offset is unnoticeable until you zoom in.
Lee
