Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    If you run Overkill first, then Extrim will work. But it will only trim the lines crossing the rectangle. It will not delete everything outside.
  2. #12
    Senior Member
    ttray33y's Computer Details
    Windows 7
    Dell Precision T3500
    XEON W3503
    16GB
    Quadro 2000
    1TB
    Dell 21" LED (DUAL)
    P&ID
    ttray33y's Discipline Details
    Process & Instrumentation Designer
    P&ID
    Design and check process diagram for consistency in accordance to PIP and company standard
    P&ID 2014
    Jun 2013
    Inside my head.
    123
    Quote Originally Posted by eldon View Post
    of course it will, but he will need to edit the system variable Peditaccept to 0 then run overkill.
    writing some noob code for him right now.
    edit:
    No need for code , just.
    1. change the peditaccept value to 0
    2. user Overkill command, select all (in my case, just to clean the entire drawing)
    3. properly place your rectangle because it seems that there are 2 of them in the drawing. join them perhaps.
    4. Use EXTRIM command.
    5. Some clean-up
    6. Done.
  3. #13
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    Quote Originally Posted by ttray33y View Post
    ...... but he will need to edit the system variable Peditaccept to 0 then run overkill.
    I have not got the system variable Peditaccept, and Overkill ran perfectly on the existing polylines.
    But don't let me stop you in your kindly lisp.
  4. #14
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    I used SSX to select all objects on the layer "SURVEY NO BOUNDARY". As long as "Optimize segments within polylines" is checked Overkill will fix the existing polylines. As Eldon said "If you run Overkill first, then Extrim will work. But it will only trim the lines crossing the rectangle." It's a routine for trimming not erasing. I use EraseOutsideBoundary to both trim & erase outside:
    Code:
     ;| Function to trim objects inside selected boundaries (allows for multiple boundaries)
        Boundaries can be "Circle, Ellipse, LWPolyline and Polyline" Entities
        Written By: Peter Jamtgaard Copyright 2015 All Rights Reserved
        ^C^C^P(or C:BoundaryTrim (load "BoundaryTrim.lsp"));BoundaryTrim
        EraseOutsideBoundary added by Tom Beauford
        ^C^C^P(or C:EraseOutsideBoundary (load "BoundaryTrim.lsp"));EraseOutsideBoundary
    ;(defun C:BT ()(c:BoundaryTrim))
    (defun C:BoundaryTrim (/ acDoc intCount ssBoundaries)
        (if (setq ssBoundaries    (ssget (list (cons 0 "Circle,Ellipse,LWPolyline,Polyline"))))
    	  (vla-startundomark (setq acDoc (vla-get-activedocument (vlax-get-acad-object))))
    	  (repeat (setq intCount (sslength ssBoundaries))
    	   (setq intCount     (1- intCount))
    	   (BoundaryTrim        (ssname ssBoundaries intCount))
    	   (BoundaryWindowErase (ssname ssBoundaries intCount)); <-Erase objects inside boundary optional
      (if	acDoc (vla-endundomark acDoc))
    ; Command line function to select objects that are windowed by a selected circle.
    (defun C:BoundarySelect (/ lstPoints objBoundary ssBoundary)
      (if (and
    	(setq ssBoundary  (ssget ":E:S" (list (cons 0 "Circle,Ellipse,LWPolyline,Polyline"))))
    	(setq objBoundary (vlax-ename->vla-object (ssname ssBoundary 0)))
    	(setq lstPoints   (SegmentPoints objBoundary 360))
        (and
         (setq ssSelections (ssget "_WP" lstPoints))
    ; Function to trim linework inside a boundary entity
    (defun BoundaryTrim (entBoundary1 / lstPoints entBoundary1 entBoundary2 lstCenter
                         lstPoints1 lstPoints2 objBoundary1 objBoundary2 ssBoundary *Error*)
      (defun *Error* ()
        (setvar "cmdecho" intCMDEcho)
      (setq intCMDEcho (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (if (and
    	(setq objBoundary1  (vlax-ename->vla-object entBoundary1))
    	(setq lstPoints1    (SegmentPoints objBoundary1 360))
    	(setq lstCenter     (mapcar '(lambda (X)(/ (apply '+ X) (length lstPoints1)))(transposematrix lstPoints1)))
    	(vl-cmdf "offset"   (/ (distance (car lstPoints1) lstCenter) 36.0) entBoundary1 lstCenter "")
    	(setq entBoundary2  (entlast))
    	(setq objBoundary2  (vlax-ename->vla-object entBoundary2))
    	(setq lstPoints2   (SegmentPoints objBoundary2 360))
         (vl-cmdf "trim" entBoundary1 "" "f")
         (foreach lstPoint lstPoints2 (vl-cmdf lstPoint))
         (vl-cmdf "" "")
         (entdel entBoundary2)
         (vl-cmdf "redraw")
    ; Function to trim linework outside a boundary entity
    (defun TrimOutsideBoundary (entBoundary1 / lstPoints entBoundary1 entBoundary2 lstCenter
                         maxpt lstPoints1 lstPoints2 objBoundary1 objBoundary2 ssBoundary *Error*)
      (defun *Error* ()
      (if (and
    	(setq maxpt (list (1+ (car (getvar 'extmax)))(1+ (cadr (getvar 'extmax)))(1+ (caddr (getvar 'extmax)))))
    	(vl-cmdf "offset"   (/ (distance (car lstPoints1) lstCenter) 200.0) entBoundary1 maxpt "")
         (vl-cmdf "" "")
         (vl-cmdf "redraw")
    ; Function to erase linework inside a boundary entity
    (defun BoundaryWindowErase (entBoundary / lstPoints objBoundary ssSelections)
      (if (and
    	(setq objBoundary  (vlax-ename->vla-object entBoundary))
        (and
         (vl-cmdf "erase" ssSelections "")
    ; Function to determine the points along a curve dividing it intSegments number of times
    (defun SegmentPoints (objCurve intSegments /  sngSegment intCount lstPoint lstPoints sngLength sngSegment)
      (if (and
    	(setq sngLength   (vlax-curve-getdistatparam objCurve (vlax-curve-getendparam objCurve)))
    	(setq sngSegment  (/ sngLength intSegments))
    	(setq intCount    0)
         (repeat (1+ intSegments)
          (setq lstPoint   (vlax-curve-getpointatdist objCurve (* intCount sngSegment)))
          (setq lstPoints  (cons lstPoint lstPoints))
          (setq intCount   (1+ intCount))
         lstPoints
    ; Function to Transpose a matrix
    (defun TransposeMatrix (lstMatrix)
      (if (car lstMatrix)
        (cons (mapcar 'car lstMatrix)
    	  (TransposeMatrix (mapcar 'cdr lstMatrix))
    ; Function to erase linework outside a boundary entity
    (defun C:EraseOutsideBoundary ( / ss1 n ssBoundary objBoundary lstPoints ssSelections entSelection)
      (setq ss1 (ssget "_X" '((67 . 0)))  n   -1)
      (if (and
    	(setq entBoundary  (ssname ssBoundary 0))
    	(ssdel entBoundary ss1)
    	(TrimOutsideBoundary entBoundary)
        (and
         (setq ssSelections (ssget "_CP" lstPoints))
         (repeat (sslength ssSelections)
           (setq entSelection (ssname ssSelections (setq n (1+ n))))
           (if(ssmemb entSelection ssSelections)(ssdel entSelection ss1))
         (command "erase" ss1 "")
    Last edited by tombu; 11th Jun 2015 at 12:27 pm. Reason: Specified "EraseOutsideBoundary" as function
  5. #15
    Senior Member
    VVA's Computer Details
    Windows 7
    Intel Core i5-2400
    8 Gb
    Nvidia Quadro 600
    Seagate 500 GB + WD 750 GB
    Philips 27"
    AutoCAD 2013
    Dec 2006
    Minsk, Belarus
    447
  1. replace an object (rectangle) with a named block and keep the hyperlink
    By Jaap Marchal in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Mar 2017, 05:17 pm
  2. How do you trim a 3d object at a 45 Degree angle?
    By dlggnation in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Jul 2015, 01:11 am
  3. Draw temporary object (Rectangle)
    By Luís Augusto in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Aug 2013, 03:45 am
  4. Rectangle around an object
    By glazier in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Apr 2012, 11:11 am
  5. How to trim a Loft object?
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jul 2010, 03:55 pm
Tags for this Thread
