Results 1 to 7 of 7
Thread: AutoCAD 2016 LT
    Forum Newbie
    AutoCAD LT 2016
    Jun 2015
    1
    Default AutoCAD 2016 LT
    Work has recently updated our CAD program from AutoCAD 2012 to AutoCAD LT 2016
    And i was wondering if there is a way to get lisp files to run on 2016
    Lisp commands like Breakline and Textmask
    If not is there similar commands to get these two running again?
    Cheers
    Michael
    AutoCAD 2013
    Nov 2011
    6,031
    Welcome to CADTutor.
    Upgrade (?) from Vanilla 2012 to 2016 LT.
    There is no lisp, no 3D, and most of the express tools use lisp too, but there are some ways to try to workaround it.
    Steven-g is an active forum member, chronic LT offender, mind bender, who has a tendency to make LT do things, for which it was not intended, I am sure he will have some valuable input for you.
    It really helps to think outside the box.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,144
    Somebody is abusing my good name , indeed LT cannot run LISP or many of the other programming languages, but in a lot of cases macro's and scripts can be made to do a lot of tasks (not all), add in a bit of diesel and it gets interesting, and if you have excel available then even better. The problem with LT is you have to forget the push button mentality. Sometimes even fairly straightforward tasks need a couple of extra steps, but you can usually find a way to semi automate most things (again not all). If you can give an explanation of what those Lisp's do and maybe some before and after results as images then somebody might be able to help. The 3D bit is debateable
    AutoCAD 2013
    Nov 2011
    6,031
    Steven, as I suspect you understand, I hold your very considerable skills in high esteem.
    You are like Merlin to LT.
    Off the top of my head I can't recall ever seeing another LT user entering a 3D modeling challenge, USING LT?
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    Steven-g are the following supported thickness, pface then this is possible.
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,144
    Dadgad, I'm still very proud of my gold star for that one.
    Bigal the thickness property is available, but not pface.
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    The walls are Thickness but sloping surfaces like the roofs are pface. It could be done as 3d line but obviously a hide will not show a 3D view. A pity there is no LT PRO that has lisp. LT LTPRO CIV3D etc
  1. AutoCAD 2016: Ribbon
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 27th Apr 2015, 01:49 pm
  2. AutoCAD 2016
    By jdits7 in forum AutoCAD General
    Last Post: 26th Mar 2015, 02:29 pm
  3. AutoCAD 2016: Layouts
    Last Post: 23rd Mar 2015, 01:10 pm
  4. AutoCAD 2016 Videos
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 20th Mar 2015, 07:20 pm
  5. Introducing AutoCAD 2016!
    Last Post: 19th Mar 2015, 05:00 pm
