I'm stuck, please help.
jonathann3891
I'm stuck and cant find a solution.
I'm writing a lisp w/ DCL that will draw tee supports. I've got the list to show up in my DCL, but when you select a steel size, its not setting any values that I've stored.
Right now I only have 2 steel sizes in the program to try and simplify it.
Can someone please point me in the right direction?
Some areas I'm sure aren't correct
    (if userclick
  (setq $COLSIZE$ (fix $COLSIZE$))
  (setq $COLSIZE$ (nth $COLSIZE$ column))
  (setq $BMSIZE$ (fix $BMSIZE$))
  (setq $BMSIZE$ (nth $BMSIZE$ beam))
Set Variables
 (defun info ()
     ((= $COLSIZE$ "W5X19")
     (SETQ COLDEPTH 5.13)
     (SETQ COLFLGTHK 0.44)
     (SETQ PLTDEPTH 0.75)
     (SETQ PLTWIDTH 12.0)
User input
      (set_tile "toselev" "000.000")
     (mode_tile "toselev" 0)
     (action_tile "toselev" "(setq TOSEL $value)")
Tee_Test.LSP
TPOLE.dcl
Hi,
You used the name of text attribute key instead of the popup_list key attribute .
