squareknees Posted June 15, 2015 Share Posted June 15, 2015 I have not been here in along time but I am looking to create a dynamic block with text that stays in the middle when the line stretches. the text will stay the same but I need it to be centered on the line no matter how long the line gets. I have searched and found a few similar questions posted on forums, but I can't even decipher how they made those work. This seems to be so simple that it is not obvious to me how to do it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 16, 2015 Share Posted June 16, 2015 A dim style can do this with arrows etc all turned off no need for a dynamic block. The defualt is normally text at middle pt. Quote Link to comment Share on other sites More sharing options...
dbroada Posted June 16, 2015 Share Posted June 16, 2015 you can move the text at the same time as your line is stretched using another stretch (or move) action with a 0.5 multiplication factor. Quote Link to comment Share on other sites More sharing options...
squareknees Posted June 16, 2015 Author Share Posted June 16, 2015 The block that I am creating is a grain direction block. it has 1/2 arrows on either end and I was using it without the word grain attached to it. I just realized that keeping the word associated with the block would make it so I would not have to go back and add the word later. I did get it figured out by stretching the mtext points. dbroada, how do you add the multiplication factor? I can't figure that one out. Thanks Quote Link to comment Share on other sites More sharing options...
dbroada Posted June 16, 2015 Share Posted June 16, 2015 I no longer have access to AutoCAD so can't look but highlight the action that you have attached the text to and use the properties palette. There are a number of options there concerning direction and multiplication. Have a play around there. Quote Link to comment Share on other sites More sharing options...
squareknees Posted June 16, 2015 Author Share Posted June 16, 2015 Thanks a ton I didn't even think to look in the standard properties box. Quote Link to comment Share on other sites More sharing options...
