Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2015
    Jun 2015
    2
    Default Layout Scale Issues
    Hello,
    The layout scale in my drawing is set to 1:1 (image 1). However, the object is clearly not 6 inches, as it would be more than half of the 8.5" width of the page (image 2).
    What is scaling the objects? How can I not have the objects scaled?
    Thank you for your time.
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    858
    1. Double Click inside the viewport.
    2. Double click the mouse wheel to zoom extents, which also centers everything in the viewport.
    3. Set the scale of the viewport. The viewport scale tool is on the right hand side of the status bar.
    4. Then lock the scale. The viewport lock icon is to the left of the viewport scale icon.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    You might also want to consider putting your viewports on their own layer and set it to "no print" in the Layer Properties Manager.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,760
    Quote Originally Posted by Brownbry10 View Post
    Hello,
    Nothing in image 1 has anything to do with "Layout Scale" as you refer to it. The only scale control on the page set up dialog is for the PLOT SCALE. The plot scale controls the scale of your ENTIRE layout page, including any title block or border line you might use. The PLOT SCALE should always be 1:1, since you always want your 8.5 x 11 page to actually print at 8.5 x 11. A reason one might change the plot scale would be to TEMPORARILY change the plot scale to fit on a different paper size for a one time print.
    On the other hand, your ANNOTATION SCALE controls the scale of the objects in the viewport. Follow profcad's instructions to set your Annotation (viewport) scale. There are a couple of methods to set this scale.
    You don't necessarily have to double click inside the viewport (making the viewport active, current). You can select the viewport frame, and then select the viewport scale from the list referred to.
    However, double click inside the unlocked viewport like profcad says to center your desired object in the viewport first. Zoom Window works for this a little better because it will center a specific area of your drawing in the viewport, rather than having Zoom Extents center ALL of modelspace in the viewport.
    If the Annotation Scale controls are not present on your task bar, click the Settings button at the far lower right of the task bar, then select Annotation Scale to be shown on the task bar.
    When you are done, click the padlock on the taskbar Annotation Scale controls to lock the viewport display, so it won't accidentally be changed. The lock is only visible when the viewport frame is selected, or when you double click inside the viewport.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Forum Newbie
    AutoCAD 2015
    Jun 2015
    2
    Quote Originally Posted by profcad View Post
    Excellent, thank you.
  1. Layout tab's viewport scale box won't show standard scale menu.
    By macsee in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2014, 01:36 pm
  2. Layout Grey Scale Plotting Issues
    By Bizkit in forum AutoCAD General
    Last Post: 13th Jun 2013, 04:30 pm
  3. Layer Issues Concerning Plant Layout
    By mrisaacpounders in forum AutoCAD General
    Last Post: 21st Feb 2012, 09:06 pm
  4. Layout Issues
    By Nylg1 in forum AutoCAD Beginners' Area
    Last Post: 28th Sep 2009, 09:54 pm
  5. Layout and printing scaling issues
    By geos in forum AutoCAD General
    Last Post: 19th Mar 2009, 03:48 pm
Tags for this Thread
