fostertom Posted June 18, 2015 Share Posted June 18, 2015 I bound (Bind>Insert) some xrefs so they became Blocks; they disappeared from the Xrefs dialog - good - I didn't need to Detach them. Then I Renamed them - but the old names persisted alonside the new names in the Rename dialog. In Purge the old names are also unpurgeable. If I QuickSelect Blocks by the old name, nothing is selected. Should I worry? Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 18, 2015 Share Posted June 18, 2015 QSELECT doesn't always work well for me. If you like lisp routines, this one will let you know if there is a reference to that block in the file. You just need to change the line "PUT THE BLOCK NAME HERE" with your block name. (defun c:findblock ( / acdoc ) (setq acdoc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for block (vla-get-blocks acdoc) (if (and (eq :vlax-false (vla-get-islayout block)) (eq :vlax-false (vla-get-isxref block)) ) (vlax-for obj block (if (vlax-property-available-p obj 'EffectiveName) (if (eq (vla-get-EffectiveName obj) "PUT THE BLOCK NAME HERE") (princ "\nBlock Found!\n") (princ "\nBlock Not Found!\n")) ) ) ) ) (vla-regen acdoc acallviewports) (princ) ) Quote Link to comment Share on other sites More sharing options...
