Results 1 to 8 of 8
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    Question Drafting projects
    I am working on my drafting projects. What is the best way to draw the lines for the floor plans? Is it okay to use the MLINE command or is there a better way to get the 6" and 4" walls?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,593
    I'm going with your profile that you are using plain AutoCAD 2010.
    IMO....
    Mlines are okay, but just recognize that they are not really mainstream in vanilla AutoCAD use (AFAIK) because most people drawing walls, etc. are using AutoCAD Arch, or some other program that has custom objects to represent those special things.
    If it comes down to some fine editing of your drawing, you may find that you have to explode the mlines to get it to look like you desire.
    Experiment and see what you think.
    R.K. McSwain
    CAD Panacea | twitter
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    We use a version of a mline that draws the 4 lines in one go and on different layers, also internal walls as 2 lines, with smart join and trim routines sorry all copyrighted. I apologise for posting this image again, need to make a new one. This is all plain jane autocad.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    If you are an experienced AutoCAD user it's possible you could do this using a continuous polyline for the footprint of the building then offset the required distance for the wall. Then you can use lines or polylines for the interior walls.
  5. #5
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor.
    I really like MLINES, and think that they are under utilized by most users, although as RK points out, there are some issues when using them.
    I have a small library of Mlines I made up for drawing common steel profiles, but I rarely use them because I tend to use SOLPROF instead from 3D Models.
    If all of your exterior walls are 6", you could quickly trace around your footprint with a multiline and create them, remember that you are in charge of the display justification, meaning relative to the base line you draw.
    If you look at the options for Multilines, you have a fair amount of control over them, when creating and defining the style.
    In the screenshot you can see those steel profile multilines which I include in my default .dwt, so if I need them, I remember which ones are available. The more elements included in the multiline, the more valuable it becomes, for a double line, OFFSET is pretty hard to beat. In the flange view multilines in my screenshot, you draw the web at the same time as the flange by drawing a single line, which is extremely accurate and fast.
    As ReMark suggested, this can quite easily be accomplished using the OFFSET command too.
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    Like others the simplest way is draw outside wall line then just offset you make a simple lisp that has the standard wall sizes pre set. There are heaps of offset code available. In the example above we have an extra routine drag a line over a wall, 4 lines and it sets then the wall spacings automatically. The code for the image is like 20 years+ old.
    Here is a simple offset routine that has extra offsets added. I know I posted a routine that was like offset 4,6,4 meaning 4" wall 6" gap 4" wall just trying to find it may be at work.
    Code:
    (defun C:MULOFF ( / obj s off)
    (vl-load-com)
    (setq obj (entsel "\nSelectObject"))
    (setq s (getpoint "\nPick Offset side"))
    (while (/= (setq off (getreal "\nEnter offset or Enter to exit")) nil)
    (vl-cmdf "_.offset" off obj s "")
    (c:muloff)
  7. #7
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    Thanks to everyone for your comments. I found that offset works wonders for me. It made completing the subdivision so much easier for Oleson Village. I followed the thread by ReMark and it made so much sense. Thank you, ReMark for your patience with those of us who are amateurs. I only have a couple if things left to do in the Village before I turn it in.
    I do have a question concerning putting the text in the drawing. How do I get the text in the place that I want it? For example, in the Oleson Village project, it says to put the bearings under the the property line. The book nor the project booklet give much info on how to do that with precision.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    You can get the text aligned in a couple of ways. This is one way....
    Invoke the SNAPANG command at the command line. When prompted to "Enter new value for SNAPANG <0>" use your mouse to pick one end of the line you want to place your text over. When prompted to "Specify second point" pick the other end of your line. Your crosshairs should now mimic the angle of the line. Use the Single Line Text feature and the Justify option. Make the justification "Center". Specify the center point of the text by selecting the midpoint of the line. Specify the height of your text. When it comes to Specifying the angle of your text pick the right hand end of the line. Type your text then hit the Enter key twice to accept it. Use the MOVE command to move the text off the line to get some space between the bottom of the text and the line itself.
    Now somewhere along the way you should have invoked the UNITS command and set the Angle type to Deg/Min/Sec and the Precision to 0d00'00". Do you recall doing that?
  1. Vault Projects - how to use projects & Vault successfully
    By Doove in forum Autodesk Inventor
    Last Post: 10th Feb 2015, 03:25 pm
  2. Pennfoster's drafting with Autocad Elective Project (civil Drafting)
    By HARPAL in forum Student Project Questions
    Last Post: 8th Jan 2013, 07:21 pm
