Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 75
  1. #21
    Full Member
    Architecture 2016
    Jun 2015
    37
    Can someone please tell me also how I get rid of the red circles (I think these may be related to hatch) and move an object along the z axis so that it lines up with the front of the unit like the others do without affecting the x or y axis?
  2. #22
    AutoCAD 2013
    Nov 2011
    6,030
    As what you are doing is Modeling, you would have much better luck learning this stuff if you switched to your 3D Basics Workspace.
    The ribbon will then display options which will have more bearing on what you are trying to do.
    In the lower right corner of your screen you will find the little GEAR icon, which is where you can choose what workspace you want to be in.
    On the SELECTION Panel, try the 3dMove gizmo.
    I can't see the red circles, but if they displayed after you started the Hatch command, they are probably highlighting areas which are not closed in the perimeter of what you hope to hatch. Read the commandline at all times, it will help you a lot.
  3. #23
    Full Member
    Architecture 2016
    Jun 2015
    37
    I admit looking at the screenshot that it is in annotation and drafting mode, but I think that is because I changed to that for colouring purposes just before I took the screenshot, I like changing workspace using the dropdown in the top left menu but appreciate the tip.
    Nothing is showing in the command line regarding the circles.
    I will have another play tonight and see if I can make progress.
  4. #24
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    I don't see any purpose for the use of hatching in a 3D model. Why wouldn't you be assigning materials to your objects or the layers they reside on?
  5. #25
    Full Member
    Architecture 2016
    Jun 2015
    37
    I didn't know you could colour without using hatch, I have been following tutorials and didn't come across any which said how to colour 3d objects any other way.
  6. #26
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    "Colour"? Well objects will obviously take on the colour of the layer they are assigned to for starters. In some cases users will, for whatever reason, override the color of an object despite the layer it is on. However, most materials come with a colour already assigned to them but the user can create custom materials, based on the ones AutoCAD provides, and assign unique colors to them.
    BTW...materials will be displayed if you switch to a Realistic visual style or invoke the Render command.
  7. #27
    Full Member
    Architecture 2016
    Jun 2015
    37
    Anyway, back to the question.
    I cannot get the object to line up with the stud wall, can someone please tell me what I need to do?
  8. #28
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by Sheepdisease View Post
    Look into the 3DMove command. The Gizmo will need relocation, but once done, you will be able to drag the box along the X axis to align it to the stud.
    Alternatively, 'Point Filters' offer another method to restrict movement to a specific axis.
  9. #29
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    If you go the Point Filter route, this thread has a good helper macro for more intuitive axis restriction:
    http://www.cadtutor.net/forum/showth...-to-touch-face
  10. #30
    Full Member
    Architecture 2016
    Jun 2015
    37
    Default Mr
    This sounds promising. I thought I had it when I tried to change the gizmo but it doesn't look like it:
    I am trying to get the shelf bracket to line up flush with the front of the rail without moving it sideways.
  1. Replies: 4
    Last Post: 18th Jun 2014, 04:32 am
  2. scale problems in viewports
    By beha in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2013, 06:43 pm
  3. Replies: 10
    Last Post: 19th Mar 2013, 11:22 am
  4. Layout with Multiple Viewports to DWG with the Viewports 'Flattened' Out
    By tkrejci in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2011, 08:45 pm
  5. Dimensions dissappearing in layout Viewports - 3d problems
    By DREWDIN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Jun 2004, 07:29 pm
