Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 75 of 75
  1. #71
    Full Member
    Architecture 2016
    Jun 2015
    37
    Hello there, tried your suggestion and it does nothing. I found the workaround was to choose the opposite option which comes up and then it is possible.
    How do I fix messed up objects like this? It should just be a rectangle, without the strange triangle chunks.
  2. #72
    AutoCAD 2013
    Nov 2011
    6,051
    When all else fails, read the instructions, or in Autocad, the commandline.
    It will give you suggestions (<default behaviour>) and offer options, which if ignored can have catastrophic consequences.
    If you are still working on your geometry, I would suggest you use 2D Wireframe, and sort it out before you start applying materials.
  3. #73
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    697
    I use this simple yet effective command so the zoom is reset to the original extents. Works every time..
    (defun c:pln ()
    (setq vctr (getvar "viewctr"))
    (setq vsize (getvar "viewsize"))
    (command "plan" "")
    (command "_.zoom" "c" vctr vsize))
  4. #74
    Full Member
    Architecture 2016
    Jun 2015
    37
    Right, so I am trying to fix the shape, and am being given instructions on how to reset the zoom level? How do I fix the strange compression on this shape?
  5. #75
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Redraw the shape and extrude.
  1. Replies: 4
    Last Post: 18th Jun 2014, 04:32 am
  2. scale problems in viewports
    By beha in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2013, 06:43 pm
  3. Replies: 10
    Last Post: 19th Mar 2013, 11:22 am
  4. Layout with Multiple Viewports to DWG with the Viewports 'Flattened' Out
    By tkrejci in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2011, 08:45 pm
  5. Dimensions dissappearing in layout Viewports - 3d problems
    By DREWDIN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Jun 2004, 07:29 pm
