Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Default Modify Xref list
    Hi,
    I have a list of Xrefs
    Xref_1 Xref_2 Xref_3_ELC Xref_4_ELC Xref_........
    I want to modify the list to only include items that have_ELC at the end.
    even better would be if i could only add Xrefs to my list that have _ELC at the end.
    both attempts below do not succeed.
    any ideas?
    Code:
    (defun c:findxref (/ td xrf)
      (setq XrfM nil)
     (while (setq td (tblnext "BLOCK" (not td)))
     (and (= (logand (cdr (assoc 70 td)) 4) 4)
     (setq xrf (cons (strcase (cdr (assoc 2 td))) xrf))
    (print xrf)
    ;attempt with Vl-remove
     (foreach n xrf
       (if (/= (wcmatch n "*_ELC")T) (vlremove n xrf)))
    ;Create new list
     (foreach n xrf
       (if (= (wcmatch n "*_ELC")T) (append n xrfm)))
      (print Xrf)
      (print Xrfm)
    Thanks
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,125
    Just a hint here .
    Code:
    (if (wcmatch n "*_ELC")
       (setq lst (append lst (list n)))
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Thanks for the hint but
    it's just not happening for me, what am I missing from your hint?
    keeps returning Nil for Xrfm
    Code:
    (defun c:findxref (/ td xrf XrfM)
      (setq XrfM '())
    (print xrf)
     (foreach n xrf
           (setq XrfM (append  n Xrfm))
      (print Xrfm)
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,125
    I am sorry , I forgot to add the list function for the append function to work with lists .
    So just add the list function for the n variable to be able to append it to the list .
    eg.
    Code:
    (foreach n xrf
          (setq XrfM (append Xrfm (list n)))
  5. #5
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,459
    Rather than removing the unwanted items from the resulting list, I would instead suggest omitting them within the initial loop, e.g.:
    Code:
    (defun c:findxref ( / td xrf xrn )
        (while (setq td (tblnext "block" (not td)))
                 (wcmatch (setq xrn (strcase (cdr (assoc 2 td)))) "*_ELC") ;; Must pass this criteria before being added to the list
                 (setq xrf (cons xrn xrf))
        (print xrf)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  6. #6
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Thanks to you both, both Options are working for me.
    regards from Austria
  7. #7
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,125
    Good for you feargt and you are welcome.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,459
    You're most welcome feargt
  9. #9
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Hi again, related to same why am I getting an error message here
    I am trying to retrieve the X value of the Insertion Point of the xrefs in my list,
    but it returns an error. If i try Option 2 and enter the Xref Name at Position "n" and only enter that on the command line, then it works. any ideas what I am missing here
    Code:
    (foreach n xrf
    OPTION 1
       (setq ss (ssget "X" '((0 . "INSERT")(67 . 0)(2 . n))))
    (setq x (car (cdr (assoc 10 (entget ss)))))
    OPTION 2
       (setq x (car (cdr (assoc 10 (entget (ssname (ssget "_X" '((2 . n))) 0))))))
    (print x)
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,125
    Try this .
    Code:
    (setq ss (ssget "_X" (list '(0 . "INSERT")'(67 . 0)(cons 2 (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) xrf))))))
  1. Modify xref path in Acad LT 2012
    By deano33 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jun 2012, 05:46 pm
  2. Replies: 0
    Last Post: 23rd Nov 2011, 03:16 am
  3. Xref Drawing List
    By TomC in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Dec 2009, 06:24 am
  4. Modify, bind, Explode XREF?
    By mikew0ng in forum AutoCAD Beginners' Area
    Last Post: 14th Aug 2006, 10:08 pm
  5. Modify > In place xref and block edit
    By edortizr6 in forum AutoCAD Beginners' Area
    Last Post: 26th Jul 2006, 02:00 pm
Tags for this Thread
