Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    my line of thining was the following
    Get list of Xref names with "*_ELC" at the end
    For each Xref in list
    get Insertion Point
    insert first new xref at Insertion Point
    insert second new xref at Insertion Point
  2. #22
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Quote Originally Posted by Tharwat View Post
    With the function vla-put-path would take care of all and using codes much better than using commands as you are planning to.
    but wont that only work with an Xref that already exists in my drawing?
  3. #23
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,247
    Quote Originally Posted by feargt View Post
    Can you explain these two phrases a little bit more ?
  4. #24
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    for example
    XREF_1_ELC and XREF_2_ELC exist in my drawing .
    they will be replaced with 2 Xrefs each
    XREF_1_ELC_Sub_1 & Xref_1_ELC_Sub_2
    XREF_2_ELC_Sub_1 & Xref_2_ELC_Sub_2
    These must be inserted at the same Insertion Point as the original XREF
  5. #25
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,247
    for example
    So did you or were you able to test the program that I posted in post No# 14 ?
  6. #26
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    no, I didn't test it because that will only replace the existing Xref, and will not insert the second xref
  7. #27
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,247
    You are wrong , as I said before after running the program you need to save and close and open the drawing again to see the changes .
  8. #28
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Code:
    (defun c:test (/ lst fnd pth)
      ;; Tharwat 23.06.2015 ;;
      (setq lst '(("Xref_1_ELC" "Xref_1_ELC_Sub1") ("Old" "New")))
      (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (if (and (= :vlax-true (vla-get-isxref blk))
                 (setq fnd (assoc (vla-get-name blk) lst))
                 (setq pth (findfile (strcat (cadr fnd) ".dwg")))
          (vla-put-path blk pth)
    )(vl-load-com)
    "Xref_1_ELC" needs to be replaced by 2 Xrefs"Xref_1_ELC_Sub1" and "Xref_1_ELC_Sub_2"
    on a side note:
    adding (vla-reload blk) to the end of the code would probably avoid having to save and reopen the drawing to see the Change
    http://forums.autodesk.com/t5/visual...h/td-p/3312595
  9. #29
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    by the way I do really appreciate your assistance on this!
  10. #30
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Quote Originally Posted by Lee Mac View Post
    Code:
    (defun c:findxref ( / idx ins sel td xrf xrn )
        (while (setq td (tblnext "block" (not td)))
            (and (= (logand (cdr (assoc 70 td)) 4) 4)
                 (wcmatch (setq xrn (strcase (cdr (assoc 2 td)))) "*_ELC") ;; Must pass this criteria before being added to the list
                 (setq xrf (vl-list* "," xrn xrf))
        (if (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (cdr xrf))))))
                (repeat (setq idx (sslength sel))
                    (setq ins (cons (cadr (assoc 10 (entget (ssname sel (setq idx (1- idx)))))) ins))
                (print ins)
            (princ "\nNo xrefs found.")
    was able to solve my problem using the code from Lee Mac by making the following modifications which gave the Name and the Insertion Point. Then while in the Repat funtion I was able to add my xrefs using the Insertion Point and delete the original.
    Code:
    (defun c:findxref ( / idx ins sel td xrf xrn Xrn2 xrefN Path)
      (setq pfad "C:/XXXX/Xrefs/")
                     (setq ins (cadr (assoc 10 (entget (ssname sel (setq idx (1- idx)))))))
                    (setq xrn2 (cdr (assoc 2 (entget (ssname sel idx)))))
                    (print (strcat xrn2 " at " (rtos x)))
            (setq xrefn (vl-string-subst "_ELC_Sub1.dwg" "_ELC" (strcase xrn2)))
           (if (findfile (strcat pfad xrefn)) (command "_.-XREF" "_overlay" (strcat pfad xrefn) (strcat (rtos x) ",0,0") "1" "1" "0"))
    (setq xrefn (vl-string-subst "_ELC_Sub2.dwg" "_ELC" (strcase xrn2)))
    Probably not the most eloquent method but it achieves the purpose!!
    Thanks again for all your help Tharwat and Lee!
  1. Modify xref path in Acad LT 2012
    By deano33 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jun 2012, 05:46 pm
  2. Replies: 0
    Last Post: 23rd Nov 2011, 03:16 am
  3. Xref Drawing List
    By TomC in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Dec 2009, 06:24 am
  4. Modify, bind, Explode XREF?
    By mikew0ng in forum AutoCAD Beginners' Area
    Last Post: 14th Aug 2006, 10:08 pm
  5. Modify > In place xref and block edit
    By edortizr6 in forum AutoCAD Beginners' Area
    Last Post: 26th Jul 2006, 02:00 pm
Tags for this Thread
