How to adjust the length of two rectangles at once
zack8576
Hi all, does anyone know how can I adjust the length of two or more rectangular shaped objects at once? I tried to put all these objects into one block, add stretch action to them, then chain the actions. That didnt work. Any info or help is greatly appreciated.
Hi Zack,
You can use your rectangular polyline command, select all 2 or 3 rectangular. Hold in the shift key while selecting the center of each rectangle line and drag the lines. Hope this makes sense.
