Results 1 to 7 of 7
    Senior Member
    not specified
    Dec 2005
    106
    Default put two diff drawings with diff scale
    Hi,
    I'm not sure if what i have done is right here. I'd like to put two drawings into one drawing in the model space and printed it out.
    For example, i have a drawing called my_pic1 and it's scaled at 1:200. Then, i was told to add another drawing because it's relevant to my_pic1. However, the added drawing looks too big and i'd like to scale it down so that i can fit it into my_pic1. I get confused when putting two different drawing with different scale onto one drawing. In the mean time, i could just leave a note for both drawing. I put a text of scale 1:200 for my_pic1 and 1:50 for the other one. Am i doing the right thing here?
    I use AutoCAD LT 2005.
    Thank you in advance
    Senior Member
    Architectural DT 2005
    Sep 2006
    334
    hi there
    you would be better creating the views in paper space or (layout) by means of the viewports toolbar then create the preferred scale directly when creating your viewport.
    That way you can set your paper correctly and produce your viewports and your desired scales.
    You can create viewports in models space then print off, but paper space is much easier to organise your work.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,417
    This is a perfect example of why you should ALWAYS draw everything at 1:1. You would then be able to combine drawings easily.
    Senior Member
    Sep 2006
    334
    I completely agree with Cad64. Drawing at 1:1 is the only way to draw.
  5. #5
    Junior Member Martin's Avatar
    Architectural DT 2008
    Sep 2006
    USA
    11
    Quote Originally Posted by iain9876 View Post
    Absolutely!
  6. #6
    Senior Member
    not specified
    Dec 2005
    106
    Thank you to you all for your replies.
    No, i totally agree with you all that all drawings should be drawn at a full scale i.e. 1:1. The first drawing i was talking about (i.e. my_pic1) is drawn at a full scaled but then, if the project manager wants it to be plotted out at, say 1:50. So what i did was just to scale up the titleblock by 50, not the actual drawing. (hope i do the right thing here)
    The second drawing i talked about is actually come from someone else. It's got the titleblock around it and it says scale - 1:20. Then, the manager came along and requested the two drawings to be put onto one drawing and have it printed out. This is when i got confused. When i copied and pasted the second drawing to the first drawing. The second drawing appeared too big. so i had to scale it down.
    Thank you once again for your input.
  7. #7
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,417
    You need to create a paper space layout. This is where you insert your title block and create viewports that you can set to whatever scale you need. Follow this link to learn more about paper space, viewports and scale:
    http://www.we-r-here.com/cad/tutorials/level_2/2-4.htm
  1. understanding drawing scale and scale factor
    By flyingal in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2012, 06:30 pm
  2. Dimensions don't scale to Viewport scale
    By brooksn in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2005, 06:18 pm
  3. Making AutoCAD drawings look like hand drawn drawings
    By ron1976uk in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2004, 01:17 pm
  4. Drawings from ADT
    By gcp310 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2004, 11:18 pm
