pixel8er Posted June 28, 2015 Share Posted June 28, 2015 Hi all I've got an issue at work with general AutoCAD slowness for users. I'm working through trying to resolve it. One of the things I'm wondering about is our network. Our IT folk have identified some issues with our network. I'm wondering what affect it might have on AutoCAD. I've run the CADalyst benchmark test on my computer both connected to the network (9 mins) and disconnected from the network (6 mins). Is this normal? Seems a big difference to me. Naturally I assume that the network would be slower than working locally but not that much. I'm going to use the Process Monitor to check what's happening but not really sure how to troubleshoot what affect the network is having on the AutoCAD performance?? Any suggestions welcome Thanks Paul Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 28, 2015 Share Posted June 28, 2015 Did you have IT temporarily disable the anti-virus program that is being used to see if that had any affect on performance? Some programs scan very aggressively even when there is no reason to. Quote Link to comment Share on other sites More sharing options...
pixel8er Posted June 28, 2015 Author Share Posted June 28, 2015 Hi ReMark iT determined that the anti-virus was causing a general slowdown to everything so they have actually just installed a new anti-virus software over the weekend so will see this week if it helps. The slowdown started about 3 or 4 months ago but the anti-virus has been the same for about 4 years. So not sure how the new anti-virus will affect AutoCAD Thanks Paul Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 28, 2015 Share Posted June 28, 2015 It could be a problem with the paths AutoCAD is forced to follow in order to find the support files that it needs. Or there are too many temp files on the network drive. Quote Link to comment Share on other sites More sharing options...
pixel8er Posted June 30, 2015 Author Share Posted June 30, 2015 What type of problem could there be with the paths? You mean paths to folders that don't exist? The support file search paths are all valid. There are 4Gb of .bak files on the network and there is 1.8Tb of free space. Also the network is 30mbps. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2015 Share Posted June 30, 2015 The paths may be too long. .BAK files are not the same as .TMP files. Quote Link to comment Share on other sites More sharing options...
Dana W Posted June 30, 2015 Share Posted June 30, 2015 You have not revisited the issues IT discovered with the network. Once these are resolved, or proven to not be a cause of AutoCad slowing down, then, and only then move on to something else. Quote Link to comment Share on other sites More sharing options...
43st Posted June 30, 2015 Share Posted June 30, 2015 We've found Autocad performance is related to network load and speed as well. If one of us is here during the weekend, with an empty office, Autocad performance is much better (30-50% faster I'd guess). I wish Autodesk would publish some information on it. It might be worth isolating our file network from the rest of the office. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 1, 2015 Share Posted July 1, 2015 We have around 1000 pc users yes that big, we have a fibre optic backbone multiple sites even real remote ones and run in my area 8 Autocads simultaneously, loading drawing is almost instant even down to being faster of the network than local. It really does sound like a network problem and out side advice may be needed. I have used a remote connection to open autocad drawings at home via my internet connection to our company server and they opened real fast none of this minutes stuff. As an ex Autocad dealer and setting up networks never really had any problems with speed, but and a big but there is so much tuning you can do behind the scenes to make one user better than another. Quote Link to comment Share on other sites More sharing options...
pixel8er Posted July 1, 2015 Author Share Posted July 1, 2015 The paths may be too long. .BAK files are not the same as .TMP files. The longest SFSP is 120 characters. There are 2.5 Gb .tmp files Quote Link to comment Share on other sites More sharing options...
pixel8er Posted July 1, 2015 Author Share Posted July 1, 2015 You have not revisited the issues IT discovered with the network. Once these are resolved, or proven to not be a cause of AutoCad slowing down, then, and only then move on to something else. IT has removed the old anti-virus and are in the process of implementing the new one. I'm not going to do anything until then. Just researching at the moment. Quote Link to comment Share on other sites More sharing options...
pixel8er Posted July 1, 2015 Author Share Posted July 1, 2015 We've found Autocad performance is related to network load and speed as well. If one of us is here during the weekend, with an empty office, Autocad performance is much better (30-50% faster I'd guess). I wish Autodesk would publish some information on it. It might be worth isolating our file network from the rest of the office. I'll ask our IT about this. Our network is 30 mbps Quote Link to comment Share on other sites More sharing options...
pixel8er Posted July 1, 2015 Author Share Posted July 1, 2015 It really does sound like a network problem and out side advice may be needed. I've run the CADalyst benchmark and I got 9 mins from the network and 6 mins from my local drive. I'm not sure other than that how to test it. Can I run a ping test? Hard to get IT to tell me that there's a network bottleneck. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 2, 2015 Share Posted July 2, 2015 6 mins to load a dwg how big ? We had stuff like this and tracked it down to a linetype found a dot linetype that was producing dots at a miniscule spacing changed it and dwg load almost instantly compared to 3 mins. As a test make everything continuous and no linetypes, purge, audit etc save as test and reload. Replace 1 linetype, 1 by 1 to find culprit. If the dwg is mega big, wblock a bit reload post it here, tell us the time to load and we can compare load time and snoop inside. Quote Link to comment Share on other sites More sharing options...
pixel8er Posted July 2, 2015 Author Share Posted July 2, 2015 6 mins to load a dwg how big ? 6 mins was the time to run the http://www.cadalyst.com/benchmark-test from my local drive. I thought the difference between running it on the network (9 mins) and running it local (6 mins) might point to a server bottleneck somewhere... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 2, 2015 Share Posted July 2, 2015 Again if ok post a real drawing as big as cad tutor allows and like me we try loading it local and network. Can then post some answers. 30mbs why not 100 that's pretty well the norm. Quote Link to comment Share on other sites More sharing options...
pixel8er Posted July 3, 2015 Author Share Posted July 3, 2015 Again if ok post a real drawing as big as cad tutor allows and like me we try loading it local and network. Can then post some answers. 30mbs why not 100 that's pretty well the norm. I'm not sure I'll be able to upload a work drawing. I'll try to find something big online...maybe an AutoDesk example dwg. The issue is not really about drawing open speed but general day to day useage. I'll ask IT about the 100mbps network and what would it take to change over. Quote Link to comment Share on other sites More sharing options...
iconeo Posted August 5, 2015 Share Posted August 5, 2015 I've noticed in the past that a lot of network slow downs can also be attributed to how users log on to the server. I'm assuming your on a windows server? Quote Link to comment Share on other sites More sharing options...
pixel8er Posted August 5, 2015 Author Share Posted August 5, 2015 I've noticed in the past that a lot of network slow downs can also be attributed to how users log on to the server. I'm assuming your on a windows server? Yes it's a windows server. The fibre is gigabit - refer attached image. I did some testing of the upload/download speeds between computers on the network - refer attached images. Quote Link to comment Share on other sites More sharing options...
