Results 1 to 9 of 9
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    Default P-F structural drafting project
    I want to again thank all of you who have been posting comments to help those of us struggling with P-F projects, especially ReMark and Hondatek. Your help is priceless.
    I have a question about the structural drafting (actually a couple). I am a novice when it comes to Autocad and drafting. But I am a quick learner. I'm a visual-tactile/kinesthetic. I learn by seeing and doing. The study units do not do such a great job of showing what the various parts look like, especially in relation to the projects we must complete. I'm still learning to transition my thinking to drafting.
    On the first plate of the project, I have to create an I-beam. It says I can create it as a block. How do I do that and how specific do I have to be? 2nd question: on plate 2 we have to show the outside elevation view of the long side 72' of the building with the underground footings. Is there some type of visual that can give me an idea of what a portion of that elevation looks like?
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    Footnote: I already drew out the sketch for plate 1, I just need to put it in Autocad. The delay was creating an I-beam block.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    Draw the I beam as you normally would then invoke the BLOCK command. Give you block a name (ex. - W8x31), specify a basepoint by picking somewhere on the geometry (ex. - endpoint or midpoint of the bottom of the I beam), under Objects select "Convert to block", then click on the Select Objects button. You'll be popped back into AutoCAD where you can select your I beam geometry. Back in the Block dialog window click on the OK button. You're done. Now copy the block where you need it or use the ARRAY command to create rows and columns containing your block.
    Re: elevation of building. There are a handful of threads that have images of what the elevation should look like. You should not have any trouble finding one.
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    I did find the threads for the elevation. Good visuals. I believe I can do that now. Silly question about the I-beam:since it is a line drawing, how do I create the beam? It is a W12x152. I looked in the appendix and it gives very specific dimensions. Do I just need to do the basic dimensions or do I need to have it with all of the specifics? I apologize for the silly questions, but once I get it, I'm good.
  5. #5
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    I've never drawn an I-beam. I'm very new to Autocad. A beginner. I'm learning pretty fast thigh. With your comments on the Oleson village, I was able to complete most of the drawing in just a few hours as opposed to the weeks I put into trying to figure out what it was actually talking about. A very difficult first project I thought.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    Draw the I beam using the specific dimensions given. The flanges are located at the top and bottom of the beam. They run horizontally and are typically thicker than the web. The web connects the two flanges and runs vertically. It is centered on the flanges. W12 refers to the rough height of the beam; 152 is the weight in pounds per lineal feet. Got all that?
    And "thank you" for your very kind comments re: my post on the Oleson Village project. Unfortunately, despite my efforts to point out errors in the instructions for some of the P-F projects they have been slow at times to follow my advice. I figure it will take another five years before they correct everything.
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Here is an example a quick google W12 x 152 beam found all the specs about the beam.
    This is an aussie beam ub250-25
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    In the "Structural Drafting with AutoCAD" PDF you were given regarding this project, on page 8, it reads...
    "All of the columns in the building are I-beams with the designation of W12 × 152. For the dimensions associated with this designation, consult Appendix H in your supplement containing the appendices and glossary. Create a layer named W12 ×152 with the color yellow and a continuous linetype."
    My advice: follow the instructions and refer to the supplement. If you do not have the supplement or have misplaced it you can find all the pertinent information you need in the Manual of Steel Construction - Allowable Stress Design as published by the AISC (American Institute of Steel Construction). Refer to page 1-28 W Shapes Dimensions. W12x152 is listed.
    Oh, never mind. Here are the rough dimensions that will suffice as far as Penn-Foster is concerned.
    Depth (i.e. - height) = 13 3/4"
    Web thickness = 7/8"
    Flange width = 12 1/2"
    Flange thickness = 1 3/8"
    Create your block on layer 0 so that when inserted on the proper layer it takes on both the color and linetype of that layer. Understand?
  9. #9
    Senior Member
    Hondatek's Computer Details
    Win7
    dell T5400, dell optiplex 745
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    keep going don't slow down. i googled a lot on this course. and this forum. I made temples on alot of stuff and i insert into drawing. like the border is all the same for every drawing. here is a video that will help you. https://youtu.be/FceS0kid-fg good luck
  1. plate #7 structural drafting from PF
    By solo8591 in forum Student Project Questions
    Last Post: 18th Jan 2013, 11:38 am
  2. Pennfoster's drafting with Autocad Elective Project (civil Drafting)
    By HARPAL in forum Student Project Questions
    Last Post: 8th Jan 2013, 07:21 pm
  3. Penn Foster Structural drafting
    By redcav01 in forum Student Project Questions
    Last Post: 30th Dec 2012, 05:01 pm
  4. Need help on structural drafting project
    By Firligic in forum Student Project Questions
    Last Post: 28th Mar 2012, 05:14 pm
  5. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
