Cant select attribute
Wow I'm able to upload! I'm trying to select the attribute to rotate with the block when I need to turn it around. But when I try to select it add to the selection set of the action I can pick the parameter but not the attribute. I thought the attribute could be treated like an object. I've selected other attributes in other blocks but not this one. Not sure why this is happening.
work template.dwg
