j_spawn_h Posted July 5, 2015 Share Posted July 5, 2015 (edited) Tharwat wrote the add text at the bottom. Which works great. Thank you! I wanted to add dialog box to add text or replace text in different places of existing text. I got it to work but I can't seem to write how not to add the text if it is already there. Example: if I had the suffix then add the suffix again it will add it not change it. I have more than one choice for suffixs and prxs. But 2 suffixs can't be in the same text string. Also I do I loop this so after I make my pick in the box I can go around and touch as many as I want to change. (defun c:Test (/ ss l sset str e suffixs prxs) (setq lstprxs '("CANT" "NOTHING") lstsuffixs '("FRB" "UWA" "UCA" "NOTHING"));end setq (or prxs (setq prxs (car lstprxs))) (or suffixs (setq suffixs (car lstsuffixs))) (setq dcl_id (load_dialog "textest.dcl")) (if (not (new_dialog "textest" dcl_id)) (exit)) (progn (set_tile prxs "1") (set_tile suffixs "1") (action_tile "prxs" "(setq prxs $value)") (action_tile "suffixs" "(setq suffixs $value)"));end progn (start_dialog) (unload_dialog dcl_id) (if (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT")))) (repeat (setq l (sslength ss)) (setq sset (ssname ss (setq l (1- l)))) (setq str (cdr (assoc 1 (setq e (entget sset))))) (entupd (cdr (assoc -1 (setq rr(entmod (subst (cons 1 (strcat prxs str suffixs )) (assoc 1 e) e))) ) ) ) ) (princ) ) (princ) ) Edited July 5, 2015 by j_spawn_h Add some text,changed title Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 6, 2015 Share Posted July 6, 2015 A couple of ways you can use a Vl-string-search to see if it exists, check the correct number of characters as prefix or suffix use (substr string start end) (substr "abcdfghk" 1 3) = abc, if this is wrong wcmatch also. Quote Link to comment Share on other sites More sharing options...
