+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Full Member
    Computer Details
    Jman's Computer Details
    Operating System:
    windows 7
    Computer:
    hp Z420 workstation
    RAM:
    8.00 GB
    Monitor:
    (2) hp zr2440w
    Discipline
    Manufacture
    Jman's Discipline Details
    Occupation
    I am a Draftsman for a Design-build company
    Discipline
    Manufacture
    Details
    I create working drawings for a Modular Building Company, Mostly Schools
    Using
    AutoCAD 2018
    Join Date
    May 2015
    Location
    Northern California
    Posts
    31
    Default Dynamic blocks for my tool palette
    I created some dynamic door blocks for our company tool palette. I had to w-block and over write the original blocks to get the dynamic block properties in them. However, when I tried to insert them in other drawings, I got an error message telling me that the block referenced itself. In anycase, I got the bright idea to open the block and copy clip it into my tool palette. This worked and I can insert it into any drawing and manipulate it without exploding it. I have also exported the files into our share folder and they do work In other user’s palettes. It’s probably nothing new but I wanted to share my success.
    F.Y.I.
    All of my tool palettes work in autocad release 2014, 2015 & 2016. I can only relate that to the fact that we save
    our drawings in 2000 format.
    We create all of our blocks in a tool palette import folder on the company drive. I also export the xtg and xpg files
    in each block folder making it easier for other users to find and import them.
  2. #2
    Forum Newbie markwheeler303's Avatar
    Discipline
    Construction
    Using
    AutoCAD 2017
    Join Date
    Oct 2017
    Posts
    9
    Default
    If you create tool palettes straight from Design Centre and keep the block library on a server all users in your office can use the same tool palettes and they will update as you add or edit dynamic blocks.
    This automates the adding of blocks to a palette and speeds the library creation process up immensely.
    The real trick here is to organise all blocks into a single folder that corresponds with the palette you wish to create. With some tidy file structure organisation you can have thousands of blocks on hundreds of palettes all easily managed and editable for an entire office.
    Making groups of palettes tidies this up further and is also exportable so all users have the same palette group structure.
    Couple of rules-
    All dynamic blocks should be created as individual files and saved with a good clean file structure on a server.
    All other users besides the administrator should have read only access and should subit blocks or edits to the admin for inclusion, gets messy otherwise.
    If the server is rebooted the admin needs to be the fisrt PC to load the tool palettes. Get IT to set up admins PC to boot immediately after the server and all other users after that, saves a huge hassle of duplicated and messed up palette files.
    Hope this helps!
  3. #3
    Full Member
    Computer Details
    Operating System:
    windows 7
    Computer:
    hp Z420 workstation
    RAM:
    8.00 GB
    Monitor:
    (2) hp zr2440w
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2015
    Location
    Northern California
    Posts
    31
    Default
    Thank you Sir,
    I guess my way is the long way around plus my tool palette doesn't automatically update. My biggest prob is getting my co-workers to use the palettes. I ended up making separate block pages such as Plumbing fixtures plan
    and elevations and because our buildings are mainly used for schools I have to create adult, Elementary and Kindergarten/preschool blocks with ADA heights as well as standard so all they have to do is open the file and copy clip
    the block they need and past it into there drawings. its been a chore lol. I have never used the Design Center but now is as good a time as any. The bad part is that i have already created 3500 blocks the other way. I'm not
    sure if i can redo my palettes.
  4. #4
    Discipline
    Construction
    Using
    AutoCAD 2017
    Join Date
    Oct 2017
    Posts
    9
    Default
    As long as ypu have the original block files organised as a single file per block, and each folder you have the blocks in corresponds with a tool palette you would like to make, design centre actually automates to palette naming and cteatiion.
    I also have many thousands of dynamic blocks and I can set up a complete new tool palette set in less than an hour total, including pointinh other users machines to the tool.palette directory. Minimal exporting required.
    I'll make a video for you showing you the process.
    It took me years to perfect, but works beautifully, evem between versions.
    The best advantage herebis design centre makes adding new blocks or editing them very simple and all users have the edits and new blocks next time they log in.
    Give me a few days and ill have a video explainijngthe process simply for you!
  5. #5
    Full Member
    Computer Details
    Operating System:
    windows 7
    Computer:
    hp Z420 workstation
    RAM:
    8.00 GB
    Monitor:
    (2) hp zr2440w
    Discipline
    Manufacture
    Occupation
    Discipline
    Manufacture
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2015
    Location
    Northern California
    Posts
    31
    Default
    Thanks Mark.
    I look forward to it. When ever you have time is fine. I appreciate it
    Jman
Similar Threads
  1. Tool Palette - Dynamic Lightening Bolt
    By iconeo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Jul 2015, 07:03 pm
  2. Help setting up a Dynamic Tool Palette
    By Taque10 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Mar 2015, 10:54 am
  3. Adding Blocks to Tool Palette
    By Krystyna in forum CAD Management
    Last Post: 3rd Jul 2013, 02:57 pm
  4. Blocks in a tool palette?
    By Siberian in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Mar 2008, 03:47 pm
  5. Repathing Tool Palette Blocks
    By lpseifert in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Dec 2007, 12:00 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
