BIGAL Posted July 7, 2015 Share Posted July 7, 2015 (edited) So many times you see a lisp ask question after question enter L, enter W, enter H. So why not a dcl that can be simply called from 1 line in a lisp maybe even 5 or 6 entries. Fully customise on the fly Title description and charcter box size. This is for using as a library function across any lisp. Slowly I am changing our lisps, much better to use a dcl no up and down the screen entries. Anyway here is getval1 2 & 3 just load it and call it with 1 line the sample call is included in the code below. It returns Val1 val2 val3 etc as strings for your use, just save the code as "Getvals.lsp" ; this is a 3 line example of code (defun c:test () (if (not AH:getval3)(load "getvals")) (ah:getval3 "Enter Length" 8 7 "Enter width" 6 5 "Enter height" 6 5) (setq pt (Getpoint "\nPick lower left corner")) (command "rectang" PT "D" (atof Val1) (atof Val2) pt) (command "extrude" "L" "" (atof val3)) (command "Vpoint" (list 1 1 1 )) ) ; Input Dialog box with variable title ; By Ah June 2015 ; credit to Alan J Thompson for original idea ;code just use these next two lines ; (if (not AH:getval1)(load "getvals")) ; (ah:getval1 "title" width limit) ; ; 1 line dcl ; sample code (ah:getval1 "line 1" 5 4) (defun AH:getval1 (title width limit / fo) (setq fname (strcat (getvar "SAVEFILEPATH") "\\getval1.dcl")) ; choose 1 of these file locations ;(setq fname (strcat (getenv "TEMP") "\\getval1.dcl")) ; temp directory defined in support paths ;(setq fname "C:\\acdatemp\\getval1.dcl") ; a existing directory you use (setq fo (open fname "w")) (write-line "ddgetval : dialog {" fo) (write-line " : row {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title (chr 34) ";" ) fo) ; these can be replaced with shorter value etc (write-line (strcat " edit_width = " (rtos width 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit 2 0) ";" ) fo) (write-line " is_enabled = true;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "ok_only;}" fo) (close fo) (setq dcl_id (load_dialog fname)) ;(setq dcl_id (load_dialog "c:\\acadtemp\\getval1")) (if (not (new_dialog "ddgetval" dcl_id)) (exit)) (action_tile "key1" "(setq val1 $value)") (mode_tile "key1" 3) (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 as a string (alert val1) ) ; 2 line dcl ; sample code (ah:getval2 "line 1" 5 4 "line2" 8 7) (defun AH:getval2 (title1 width1 limit1 title2 width2 limit2 / fo) (setq fname (strcat (getvar "SAVEFILEPATH") "\\getval2.dcl")) ; choose 1 of these file locations ;(setq fname (strcat (getenv "TEMP") "\\getval2.dcl")) ; temp directory defined in support paths ;(setq fname "C:\\acdatemp\\getval2.dcl") ; a existing directory you use (setq fo (open fname "w")) (write-line "ddgetval2 : dialog {" fo) (write-line " : column {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title1 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width1 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit1 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key2" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title2 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width2 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit2 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_only;}" fo) (close fo) ; code part (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval2" dcl_id)) (exit)) (mode_tile "key1" 3) (action_tile "key1" "(setq val1 $value)") (mode_tile "key2" 3) (action_tile "key2" "(setq val2 $value)") (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 and val2 as strings (alert (strcat val1 "\n" val2)) ; remove this line in finished code ) ; 3 line dcl ; sample code (ah:getval3 "line 1" 5 4 "line2" 8 7 "line3" 6 4) (defun AH:getval3 (title1 width1 limit1 title2 width2 limit2 title3 width3 limit3 / fo) (setq fname (strcat (getvar "SAVEFILEPATH") "\\getval3.dcl")) ; choose 1 of these file locations ;(setq fname (strcat (getenv "TEMP") "\\getval3.dcl")) ; temp directory defined in support paths ;(setq fname "C:\\acdatemp\\getval3.dcl") ; a existing directory you use (setq fo (open fname "w")) (write-line "ddgetval3 : dialog {" fo) (write-line " : column {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title1 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width1 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit1 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key2" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title2 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width2 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit2 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key3" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title3 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width3 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit3 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_only;}" fo) (close fo) ; code part (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval3" dcl_id)) (exit)) (mode_tile "key1" 3) (action_tile "key1" "(setq val1 $value)") (mode_tile "key2" 3) (action_tile "key2" "(setq val2 $value)") (mode_tile "key3" 3) (action_tile "key3" "(setq val3 $value)") (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 and val2 val3 as strings (alert (strcat val1 "\n" val2 "\n" val3)) ; remove this line in finished code ) Edited July 24, 2015 by BIGAL screwy character removed from 1st line. Quote Link to comment Share on other sites More sharing options...
tombu Posted July 7, 2015 Share Posted July 7, 2015 Nice! I've only added dcl to a few routines and none lisp generated. I don't have a "c:\\acadtemp" folder gonna try (getvar "SAVEFILEPATH") Quote Link to comment Share on other sites More sharing options...
AIberto Posted July 7, 2015 Share Posted July 7, 2015 Yes, It's Nice , But , I think I need some example . Quote Link to comment Share on other sites More sharing options...
tombu Posted July 7, 2015 Share Posted July 7, 2015 It's basically 3 examples in one file - AH:getval1, AH:getval2, & AH:getval3 for 1, 2, or 3 inputs allowing you to set the size of the dialog box with the call. After using one of the example calls like (ah:getval3 "Enter Length" 8 7 "Enter width" 6 5 "Enter height" 6 5) open the dcl file from the temp folder to check it out. Quote Link to comment Share on other sites More sharing options...
tombu Posted July 7, 2015 Share Posted July 7, 2015 (edited) Changed it to use default AutoCAD temp folder since I don't have a "C://acadtemp" folder: ;| Input Dialog box with variable title By Ah June 2015 http://www.cadtutor.net/forum/showthread.php?93002-1-line-2-line-3line-dcl-auto-generator-plus-more-if-required&p=636641&viewfull=1#post636641 Modified to use (getenv "temp") by Tom Beauford code just use these next two lines (if (not AH:getval1)(load "getvals")) (ah:getval1 "title" width limit) |; ; 1 line dcl ; sample code(ah:getval1 "line 1" 5 4) (defun AH:getval1 (title width limit / fname fo dcl_id val1) (setq fname (strcat (getenv "temp") "\\getval1.dcl")) (setq fo (open fname "w")) (write-line "ddgetval : dialog {" fo) (write-line " : row {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title (chr 34) ";" ) fo) ; these can be replaced with shorter value etc (write-line (strcat " edit_width = " (rtos width 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit 2 0) ";" ) fo) (write-line " is_enabled = true;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "ok_only;}" fo) (close fo) (setq dcl_id (load_dialog fname)) ;(setq dcl_id (load_dialog "c:\\acadtemp\\getval1")) (if (not (new_dialog "ddgetval" dcl_id)) (exit)) (action_tile "key1" "(setq val1 $value)") (mode_tile "key1" 3) (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 as a string (alert val1) ) ; 2 line dcl ; sample code (ah:getval2 "line 1" 5 4 "line2" 8 7) (defun AH:getval2 (title1 width1 limit1 title2 width2 limit2 / fname fo dcl_id val1 val2) (setq fname (strcat (getenv "temp") "\\getval2.dcl")) (setq fo (open fname "w")) (write-line "ddgetval2 : dialog {" fo) (write-line " : column {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title1 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width1 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit1 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key2" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title2 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width2 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit2 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_only;}" fo) (close fo) ; code part (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval2" dcl_id)) (exit)) (mode_tile "key1" 3) (action_tile "key1" "(setq val1 $value)") (mode_tile "key2" 3) (action_tile "key2" "(setq val2 $value)") (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 and val2 as strings (alert (strcat val1 " " val2)) ) ; 3 line dcl ; sample code (ah:getval3 "line 1" 5 4 "line2" 8 7 "line3" 6 4) (defun AH:getval3 (title1 width1 limit1 title2 width2 limit2 title3 width3 limit3 / fname fo dcl_id val1 val2 val3) (setq fname (strcat (getenv "temp") "\\getval3.dcl")) (setq fo (open fname "w")) (write-line "ddgetval3 : dialog {" fo) (write-line " : column {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title1 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width1 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit1 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key2" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title2 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width2 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit2 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key3" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title3 (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width3 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit3 2 0) ";" ) fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_only;}" fo) (close fo) ; code part (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval3" dcl_id)) (exit)) (mode_tile "key1" 3) (action_tile "key1" "(setq val1 $value)") (mode_tile "key2" 3) (action_tile "key2" "(setq val2 $value)") (mode_tile "key3" 3) (action_tile "key3" "(setq val3 $value)") (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of val1 and val2 val3 as strings (alert (strcat val1 "\n" val2 "\n" val3)) ) Edited July 8, 2015 by tombu Switched to using (getenv "temp") Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 7, 2015 Author Share Posted July 7, 2015 No worries tombu we just have everybody with a local temp directory and its part of our profile, I have changed my original post but for your info need this change double backslashes \\getval1 to path name. Quote Link to comment Share on other sites More sharing options...
tombu Posted July 8, 2015 Share Posted July 8, 2015 No worries tombu we just have everybody with a local temp directory and its part of our profile, I have changed my original post but for your info need this change double backslashes \\getval1 to path name. (getvar "SAVEFILEPATH") returns "C:\\Users\\BeaufordT\\appdata\\local\\temp\\" with double backslashes at the end so (strcat (getvar "SAVEFILEPATH") "getval1.dcl") returns "C:\\Users\\BeaufordT\\appdata\\local\\temp\\getval1.dcl" while while (strcat (getvar "SAVEFILEPATH") "\\getval1.dcl") returns "C:\\Users\\BeaufordT\\appdata\\local\\temp\\\\getval1.dcl" After further thought (getenv "temp") which returns "C:\\Users\\BEAUFO~1\\AppData\\Local\\Temp" would be better since SAVEFILEPATH is where autosave sv$ files are saved. While normally the same you can change SAVEFILEPATH without changing the Temp folder location. So I changed it to (strcat (getenv "temp") "\\getval1.dcl") in my previously post. Quote Link to comment Share on other sites More sharing options...
stevesfr Posted July 8, 2015 Share Posted July 8, 2015 No worries tombu we just have everybody with a local temp directory and its part of our profile, I have changed my original post but for your info need this change double backslashes \\getval1 to path name. AL, getval.lsp from 2012 works perfect. I cannot get getvals.lsp to write the dcl files to my temp directory (which I have set correctly) any suggestions or example of what I may doing wrong. Steve Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 9, 2015 Author Share Posted July 9, 2015 Tombu interesting getting different results Command: (strcat (getvar "SAVEFILEPATH") "\\getval1.dcl") "C:\\AcadTemp\\getval1.dcl" Command: (getvar "SAVEFILEPATH") "C:\\AcadTemp" (strcat (getvar "SAVEFILEPATH") "getval1.dcl") "C:\\AcadTempgetval1.dcl" Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 9, 2015 Author Share Posted July 9, 2015 stevesfr simplest way is to just hard code the directory we have a c:\Acadtemp which was what I posted first then changed the code to try to be more generic as another posted did not have Acadtemp. ; replace (setq fname (strcat (getvar "SAVEFILEPATH") "\\getval1.dcl")) (setq fname "C:\\mychoice of directory")) ; note 3 times in code Quote Link to comment Share on other sites More sharing options...
tombu Posted July 9, 2015 Share Posted July 9, 2015 Tombu interesting getting different results Command: (strcat (getvar "SAVEFILEPATH") "\\getval1.dcl") "C:\\AcadTemp\\getval1.dcl" Command: (getvar "SAVEFILEPATH") "C:\\AcadTemp" (strcat (getvar "SAVEFILEPATH") "getval1.dcl") "C:\\AcadTempgetval1.dcl" Since SAVEFILEPATH where autosave sv$ files isn't always the same as AutoCAD's temp folder I modified the code yesterday anyway. I still have Civil 3D 2013 on my PC though and (getvar "SAVEFILEPATH") returns "C:\\Users\\BeaufordT\\appdata\\local\\temp\\" on it as well. Wondering if it's a file system thing, I'm on Windows 7 64 bit what's your operating system? Did (getenv "temp") give you your temp folder "C:\\AcadTemp"? I'd like to be able to post file related code in the future that would work on other PCs can you help me figure out a solution for this? What does (getvar "roamablerootprefix") result in on your PC? What about (vl-filename-directory (getenv "QnewTemplate")) ? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 10, 2015 Author Share Posted July 10, 2015 I must apologise to Alan J Thompson for not acknowledging original code but this is what he used (setq fo (open (setq fn (vl-filename-mktemp "" "" ".dcl")) "w")) I am on WIN 7 64bit. Lee, Remark any comment ? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 11, 2015 Author Share Posted July 11, 2015 (edited) A better solution may be using (strcat (getenv "temp") "\\getval1.lsp")) it still needs the \\ slashes I have edited my original code to have 3 choices. Edited July 11, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
tombu Posted July 12, 2015 Share Posted July 12, 2015 A better solution may be using (strcat (getenv "temp") "\\getval1.lsp")) it still needs the \\ slashes I have edited my original code to have 3 choices. Both our (getenv "temp") need the \\ double backslashes at the end which is both consistent and the actual location of AutoCAD's temp file. I've never found a need to change the location of either the temp or SAVEFILEPATH, mine are both out the box locations glad temp worked the same for both of us. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 1, 2016 Author Share Posted May 1, 2016 This is the latest version and basicly you can have as many lines as you like its all worked out from the 1 calling line, problem is it does not work I need help see code in red. The other way around is by somehow creating variables on the fly. ; multi line dcl ; sample code a 3 line example ; (AH:getvals (list "Line 1" 5 4 "line 2" 2 4 "line 3" 8 7)) (defun AH:getvals (INFO / fo fname newlst num x y) ; you can hard code a directory if you like for dcl file ;(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) (setq fo (open (setq fname "c:\\temp\\getvals.dcl") "w")) (write-line "ddgetval : dialog {" fo) (write-line " : column {" fo) (setq num (/ (length info) 3)) (setq newlst '()) (repeat num (setq newlst (cons "-" newlst)) ) (setq x 1) (setq y 1) (repeat num (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) (strcat "key" (rtos y 2 0)) (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) (nth (- x 1) info) (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos (nth x info) 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos (nth (+ x 1) info) 2 0) ";" ) fo) (write-line " is_enabled = true;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (setq x (+ x 3)) (setq y (+ y 1)) ) (write-line " }" fo) (write-line "ok_only;}" fo) (close fo) (setq x 1) (setq outlst '()) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval" dcl_id)) (exit)) (setq x 0) (repeat num ;(action_tile (strcat "key" (rtos x 2 0) ) "(setq val1 $value)") (action_tile (strcat "key" (rtos x 2 0)) "[color="red"](subst $value (nth x newlst) newlst )[/color]") (mode_tile (strcat "key" (rtos x 2 0)) 3) (setq x (+ x 1)) ) (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of keys as strings in list newlst ;(vl-file-delete fname) ) ; defun Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 1, 2016 Share Posted May 1, 2016 This is the latest version and basicly you can have as many lines as you like its all worked out from the 1 calling line, problem is it does not work I need help see code in red. The other way around is by somehow creating variables on the fly. ; multi line dcl ; sample code a 3 line example ; (AH:getvals (list "Line 1" 5 4 "line 2" 2 4 "line 3" 8 7)) (defun AH:getvals (INFO / fo fname newlst num x y) ; you can hard code a directory if you like for dcl file ;(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) (setq fo (open (setq fname "c:\\temp\\getvals.dcl") "w")) (write-line "ddgetval : dialog {" fo) (write-line " : column {" fo) (setq num (/ (length info) 3)) (setq newlst '()) (repeat num (setq newlst (cons "-" newlst)) ) (setq x 1) (setq y 1) (repeat num (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) (strcat "key" (rtos y 2 0)) (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) (nth (- x 1) info) (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos (nth x info) 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos (nth (+ x 1) info) 2 0) ";" ) fo) (write-line " is_enabled = true;" fo) (write-line " }" fo) (write-line "spacer_1 ;" fo) (setq x (+ x 3)) (setq y (+ y 1)) ) (write-line " }" fo) (write-line "ok_only;}" fo) (close fo) (setq x 1) (setq outlst '()) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetval" dcl_id)) (exit)) (setq x 0) (repeat num ;(action_tile (strcat "key" (rtos x 2 0) ) "(setq val1 $value)") (action_tile (strcat "key" (rtos x 2 0)) "[color="red"](subst $value (nth x newlst) newlst )[/color]") (mode_tile (strcat "key" (rtos x 2 0)) 3) (setq x (+ x 1)) ) (start_dialog) (done_dialog) (unload_dialog dcl_id) ; returns the value of keys as strings in list newlst ;(vl-file-delete fname) ) ; defun Maybe you need @LeeMac. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 1, 2016 Share Posted May 1, 2016 (edited) Morning BigAl ! I must admit that I am very rusty on DCL. I've dug thru your early posts and early correspondences and think it is a great idea. Here is how I've approached in the past ( with some tweaks for this thread ) [b][color=BLACK]([/color][/b]defun c:gendcl [b][color=FUCHSIA]([/color][/b]/ tiles kl fn wf key lab def vtp id action output code val typ [color=#8b4513]; a q x y z[/color] [b][color=FUCHSIA])[/color][/b] [color=#8b4513];;;25 SINGLE CHARACTER VARIABLES MAX A->Z EXCLUDE T[/color] [color=#8b4513];;; key label default type[/color] [b][color=FUCHSIA]([/color][/b]setq tiles [b][color=NAVY]([/color][/b]if gv_tiles gv_tiles [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]list [color=#2f4f4f]"A"[/color] [color=#2f4f4f]"App"[/color] [color=#2f4f4f]"Open"[/color] [color=#2f4f4f]"STR"[/color][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]list [color=#2f4f4f]"Q"[/color] [color=#2f4f4f]"Qty"[/color] [color=#2f4f4f]"1"[/color] [color=#2f4f4f]"INT"[/color][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]list [color=#2f4f4f]"X"[/color] [color=#2f4f4f]"Width"[/color] [color=#2f4f4f]"24"[/color] [color=#2f4f4f]"REAL"[/color][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]list [color=#2f4f4f]"Y"[/color] [color=#2f4f4f]"Length"[/color] [color=#2f4f4f]"48"[/color] [color=#2f4f4f]"REAL"[/color][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]list [color=#2f4f4f]"Z"[/color] [color=#2f4f4f]"Height"[/color] [color=#2f4f4f]"36"[/color] [color=#2f4f4f]"REAL"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]foreach v tiles [b][color=NAVY]([/color][/b]setq kl [b][color=MAROON]([/color][/b]cons [b][color=GREEN]([/color][/b]car v[b][color=GREEN])[/color][/b] kl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]set [b][color=MAROON]([/color][/b]read [b][color=GREEN]([/color][/b]car v[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]nth 2 v[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq fn [color=#2f4f4f]"gen.dcl"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq wf [b][color=NAVY]([/color][/b]open fn [color=#2f4f4f]"w"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]write-line [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"dcl_settings : default_dcl_settings { audit_level = 0; }"[/color][b][color=NAVY])[/color][/b] wf[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]write-line [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"fdiin : dialog { label = \"[/color]Generic DCL Inputs\[color=#2f4f4f]" ;"[/color][b][color=NAVY])[/color][/b] wf[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]write-line [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]" : column {"[/color][b][color=NAVY])[/color][/b] wf[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]foreach v tiles [b][color=NAVY]([/color][/b]setq key [b][color=MAROON]([/color][/b]nth 0 v[b][color=MAROON])[/color][/b] lab [b][color=MAROON]([/color][/b]nth 1 v[b][color=MAROON])[/color][/b] def [b][color=MAROON]([/color][/b]nth 2 v[b][color=MAROON])[/color][/b] vtp [b][color=MAROON]([/color][/b]nth 3 v[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]write-line [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]" : row { "[/color][b][color=MAROON])[/color][/b] wf[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]write-line [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]" : edit_box {key = \"[/color][color=#2f4f4f]" key "[/color]\[color=#2f4f4f]""[/color] [color=#2f4f4f]" ; label = \"[/color][color=#2f4f4f]" [b][color=GREEN]([/color][/b]strcat key "[/color] [color=#2f4f4f]" lab[b][color=GREEN])[/color][/b] "[/color]:\[color=#2f4f4f]""[/color] [color=#2f4f4f]" ; value = \"[/color][color=#2f4f4f]" def "[/color]\[color=#2f4f4f]""[/color] [color=#2f4f4f]" ; edit_width = 20 "[/color] [color=#2f4f4f]" ; alignment = \"[/color]right\[color=#2f4f4f]""[/color] [color=#2f4f4f]" ; mnemonic = \"[/color][color=#2f4f4f]" key "[/color]\[color=#2f4f4f]" "[/color] [color=#2f4f4f]"; }}"[/color] [b][color=MAROON])[/color][/b] wf[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]write-line [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]" }"[/color][b][color=NAVY])[/color][/b] wf[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]write-line [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]" : row { ok_cancel ; }}"[/color][b][color=NAVY])[/color][/b] wf[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]close wf[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq id [b][color=NAVY]([/color][/b]load_dialog fn[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]new_dialog [color=#2f4f4f]"fdiin"[/color] id[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]foreach k kl [b][color=NAVY]([/color][/b]action_tile k [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"[b][color=GREEN]([/color][/b]setq "[/color] k [color=#2f4f4f]" [b][color=BLUE]([/color][/b]get_tile \"[/color][color=#2f4f4f]" k "[/color]\[color=#2f4f4f]"[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]action_tile [color=#2f4f4f]"accept"[/color] [color=#2f4f4f]"[b][color=NAVY]([/color][/b]done_dialog 1[b][color=NAVY])[/color][/b]"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]action_tile [color=#2f4f4f]"cancel"[/color] [color=#2f4f4f]"[b][color=NAVY]([/color][/b]done_dialog 0[b][color=NAVY])[/color][/b]"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq action [b][color=NAVY]([/color][/b]start_dialog[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]unload_dialog id[b][color=FUCHSIA])[/color][/b] [color=#8b4513];;;CREATE GLOBAL TILES LIST[/color] [b][color=FUCHSIA]([/color][/b]setq gv_tiles nil[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]foreach v [b][color=NAVY]([/color][/b]reverse tiles[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq gv_tiles [b][color=MAROON]([/color][/b]cons [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]nth 0 v[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]nth 1 v[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]eval [b][color=RED]([/color][/b]read [b][color=PURPLE]([/color][/b]nth 0 v[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]nth 3 v[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] gv_tiles[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513];;;CREATE OUTPUT LIST[/color] [b][color=FUCHSIA]([/color][/b]foreach k kl [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]> action 0[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq output [b][color=GREEN]([/color][/b]cons [b][color=BLUE]([/color][/b]strcat k [b][color=RED]([/color][/b]eval [b][color=PURPLE]([/color][/b]read k[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] output[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]set [b][color=GREEN]([/color][/b]read k[b][color=GREEN])[/color][/b] nil[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513];;;FORMAT VALUES[/color] [b][color=FUCHSIA]([/color][/b]foreach v output [b][color=NAVY]([/color][/b]setq code [b][color=MAROON]([/color][/b]substr v 1 1[b][color=MAROON])[/color][/b] val [b][color=MAROON]([/color][/b]substr v 2[b][color=MAROON])[/color][/b] typ [b][color=MAROON]([/color][/b]nth 3 [b][color=GREEN]([/color][/b]assoc code tiles[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]set [b][color=MAROON]([/color][/b]read code[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]cond [b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]= typ [color=#2f4f4f]"REAL"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]atof val[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]= typ [color=#2f4f4f]"INT"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]atoi val[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]= typ [color=#2f4f4f]"STR"[/color][b][color=BLUE])[/color][/b] val[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1 output[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] I'm sure yours is a typo or small format problem as they worked before Good Luck ! -David Edited May 2, 2016 by David Bethel Flushed out the code Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 2, 2016 Author Share Posted May 2, 2016 Thanks David The foreach k kl is what I need in particular the action-tile part I went a bit to simple. Like the idea of auto number or string the returned values. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 2, 2016 Share Posted May 2, 2016 You're welcome, I flushed out the code some in post #16 Added a global variable for memory in the current session only Added the conversion segment. It is just a starting point but should come in handy for the folks that like DCL inputs -David Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 3, 2016 Author Share Posted May 3, 2016 Maybe chage this (/ tiles kl fn to (tiles / kl fn would allow a preloaded version and any number of lines. Quote Link to comment Share on other sites More sharing options...
