enthralled Posted July 7, 2015 Share Posted July 7, 2015 Hi, I have the following plan showing 3 roads (yellow, red and cyan) and a pipe line (magenta): https://drive.google.com/file/d/0B6Xql6Q_IBP-Rlp2em1aRWNSWnM/view?usp=sharing I need to create a section at each green line, showing where the roads and pipeline are crossing (with their respective colors), as follows: https://drive.google.com/file/d/0B6Xql6Q_IBP-QWppZWFyUDBRZTg/view?usp=sharing Any easy way to do this? Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 7, 2015 Share Posted July 7, 2015 Aren't you missing something? Wouldn't a section cut through a road show such features as the crown of the road, the pitch of the road, the curb, and what the land on either side of the road is doing (sloped, flat, irregular)? And wouldn't the pipe, in section, be shown as a circle? Is this strictly a 2D drawing you are working with? And is this all being done in plain AutoCAD? Quote Link to comment Share on other sites More sharing options...
enthralled Posted July 7, 2015 Author Share Posted July 7, 2015 I do profiles of natural ground using civil3d, and I can specify stations (by inserting PI) at each alignment (green line) on plan view, which will appear as straight line in profile view. problem with this is all stations I make will have the same color, and it's hard to differentiate each road by color in profile view. I can currently get this: https://drive.google.com/file/d/0B6Xql6Q_IBP-ZUl3RXFsUEFOYkE/view?usp=sharing I need something like this: https://drive.google.com/file/d/0B6Xql6Q_IBP-dkN2RFlhMEhvOEE/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 8, 2015 Share Posted July 8, 2015 Why not save your profile views to a layout you can put a name on each then. I have 12 roads layout & long, then cross sections = 88 layouts. The name is on the bottom of the title block. Quote Link to comment Share on other sites More sharing options...
Organic Posted July 12, 2015 Share Posted July 12, 2015 I do profiles of natural ground using civil3d, and I can specify stations (by inserting PI) at each alignment (green line) on plan view, which will appear as straight line in profile view. problem with this is all stations I make will have the same color, and it's hard to differentiate each road by color in profile view. I can currently get this:https://drive.google.com/file/d/0B6Xql6Q_IBP-ZUl3RXFsUEFOYkE/view?usp=sharing I need something like this: https://drive.google.com/file/d/0B6Xql6Q_IBP-dkN2RFlhMEhvOEE/view?usp=sharing Not sure if this can be controlled somewhere in the Civi 3D style settings? I've moved to a different software package now and it would be very easy to do this in that so I'd be surprised if this isn't also possible in Civil 3D somehow. Quote Link to comment Share on other sites More sharing options...
enthralled Posted July 12, 2015 Author Share Posted July 12, 2015 Not sure if this can be controlled somewhere in the Civi 3D style settings? I've moved to a different software package now and it would be very easy to do this in that so I'd be surprised if this isn't also possible in Civil 3D somehow. I haven't found a way to do it yet. What software package has this? Quote Link to comment Share on other sites More sharing options...
Organic Posted July 12, 2015 Share Posted July 12, 2015 I haven't found a way to do it yet. What software package has this? http://www.12d.com/ Quote Link to comment Share on other sites More sharing options...
