Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    Default Could Greatly Use Some Help with Plotting Multiple Sheets At Once
    Okay, so i feel very stupid for asking for help with this but to save my life I cannot figure this out. We have anywhere from 30-50 sheets for site plans. Opening each sheet and plotting them takes anywhere from 30 min. to an hour. This is taking up too much time when I should be drafting instead of hitting the open, plot, close buttons. Can someone please explain to me from start to finish of how to, I guess, set up sheet sets to plot the whole set of plans at once? I think a sheet set would be used. Not sure about that though. I would GREATLY appreciate any help. Thanks everyone.
    Miller
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    863
    You can also use the Publish command to print multiple sheets at once.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    Not exactly a start to finish answer but I will take a look into it thanks Professor!
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    When having to go back and produce plots of drawings, I too would recommend either PUBLISH, or a Script (.SCR) that uses PLOT/-PLOT... If you want something similar, but faster, then employ Core Console in parallel (aka multiple, simultaneous instances).
    That said, to avoid ALL of this moving forward, simply use the Autopublish Mechanism (first released back in 2009), which produces PDF/DWF at either drawing SAVE* or CLOSE (user configurable)... This process is exponentially faster than either PLOT, or PUBLISH, and allows you to always have a current plan set, as your work is saved. Rather than performing a PUBLISH for specific sub-set to sendout, simply combine the PDFs already produced in kind, and print, email, etc.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    There is a selection in your publish options to pick either single sheets or one multi-sheet document.
    Once that is set up, all you have to do is click the output tab on your ribbon, then click Batch Plot, (2015, right?) select the sheets you want to plot (by right-click removing the ones you don't need, like modelspace) and then clicking the publish button. The sheet list can be named and saved if you wish to do so.
    Batch plot, by default will want to plot all currently open drawings for the same instance of AutoCad, so if you don't want to spend a lot of time removing sheets from your list, only have open the drawings you wish to plot now. Batch plot will plot all sheets in the current list to the same multi-page file, which can include more that one open dwg file, so if you don't want that you have to watch out for it.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    Right on! Thank you very much! I look forward to putting this to good use! Running road profiles and corridors right now so don't have time to take a look at it.
  8. #8
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by MillerMG View Post
    ... Running road profiles and corridors right now....
    Same here
  9. #9
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    Got everything to work out with no issues at all. Thanks everyone!
  10. #10
    Junior Member
    Civil 3D 2013
    Nov 2014
    16
    Default Hopefully, a helpful suggestion
    You might also want to look into sheet sets. At the very least, they can be invaluable in plotting large numbers of drawings at the touch of a few buttons. At the most, you can open and plot drawings through the sheet set manager (SSM), and even edit certain title block information (if set up properly) in drawings without ever opening them. Have a look...
  1. multiple plotting of different sheets in 1 drawing
    By charmrus2000 in forum AutoCAD Drawing Management & Output
    Last Post: 11th Nov 2012, 11:28 pm
  2. Multiple sheets. Single or multiple DWG files?
    By uhcafigdc in forum CAD Management
    Last Post: 15th Dec 2010, 02:01 pm
  3. plotting multiple sheets to one pdf file
    By michaeloureiro in forum AutoCAD Drawing Management & Output
    Last Post: 6th Feb 2010, 03:39 pm
  4. plotting multiple sheets
    By slimjramirez in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2006, 04:49 pm
  5. Plotting Multiple sheets
    By GSwariior in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2006, 03:36 am
Tags for this Thread
