Results 1 to 7 of 7
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    Unhappy Doors and windows
    I have several floor plans drawn for my projects. This is probably a silly question, but I'm going to ask it anyway. I can't seem to find out. How do I draw the doors and windows on the floor plans? I have the schedules, but is there a certain way it is supposed to look? I have the places where they are supposed to be marked, but how do I draw them so they will be recognized as doors and windows? I've checked the threads, but I couldn't find the answer that applies to what I'm asking.
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    I think I figured it out-at least for the windows, I think. I still could use a little help with the doors.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,737
    You'll be including a door and window schedule as well?
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by Legacy14 View Post
    Doors and windows don't have to be all that detailed unless it's the door or window itself that is being detailed out. Simple symbols are enough, as in the attached picture. The opening width should be accurate (nominally) though. The windows can also be only one horizontal line instead of two like the ones in my drawing. Don't bother drawing any moldings, mullions, muntins, knobs or hinges. By "Nominally" I mean the nominal size of the door. A 3068 (3'-0" x 6'-8") door can have the opening drawn 3'-0" wide. No need to account for the fact that it is the door panel itself that is 3'-0" wide, plus the frame and rough opening. That stuff goes into the door schedule, and/or finish specification documents where the masons and framers can find it.
    By the way, AutoCad has door and window blocks that come with it, in the tool pallets, click TOOLS >> Pallets >> Architectural tab. See the second image.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    I do have the door and window schedule. What I did so far is I figured out how to do the windows with the horizontal line. For the doors I have only cut out the locations of the doors using the schedule. I wasn't sure if I had to have the curve of the door at a particular angle, etc. Also, the outside doors look different. I believe there are some sliding doors as well.
  6. #6
    Junior Member
    AutoCAD 2010
    Nov 2014
    13
    I'm gradually learning how to think through the process. Also, I realize that wisdom is not always knowing how to do it at first, but knowing where to find the answers and who to consult. Thank you again ReMark for all of your threads. You must be in the business to be so knowledgeable.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,737
    Any good architectural drafting and design book would have the information you seek.
    Generally speaking the arc defining the swing of the door is set at ninety degrees although I have seen some companies use 45 degrees.
    One of many references available...http://cset.sp.utoledo.edu/~nkissoff...100/FP1-5a.pdf
    Scroll down until you get to the section re: doors in floor plan.
  1. In need of more walls, windows & doors
    By Nick-H- in forum Revit General
    Last Post: 8th Dec 2010, 06:39 pm
  2. 3D blocks of doors and windows
    By CAD911 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Apr 2010, 01:18 pm
  3. Doors and Windows
    By ben101965 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Oct 2008, 06:06 am
  4. No Blocks for Windows or Doors
    By rc0213 in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2008, 06:30 am
  5. Importing Doors And Windows
    Last Post: 3rd Apr 2008, 02:27 pm
