cadman42k Posted July 13, 2015 Share Posted July 13, 2015 My select file dialog box has stopped working. When I click "open" or "save-as", I get the command prompt with the default path set to where I am. I tried re-installing Autocad...still there...maybe a Windows issue? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 13, 2015 Share Posted July 13, 2015 Change FILEDIA to 1. Quote Link to comment Share on other sites More sharing options...
cadman42k Posted July 13, 2015 Author Share Posted July 13, 2015 thank you! Funny how that variable just changed itself... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 14, 2015 Share Posted July 14, 2015 It doesn't change itself. This usually happens when certain LISP routines are terminated before they have ended. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted July 14, 2015 Share Posted July 14, 2015 thank you! Funny how that variable just changed itself... If you're using 2015 or earlier, you can use the code here to "monitor" certain system variables (your choice), and it will alert you or simply change the back to normal if something changes them If you're using 2016, there is a built-in tool to do this. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 14, 2015 Share Posted July 14, 2015 Deja vu... Quote Link to comment Share on other sites More sharing options...
