Floor & ceiling
wimal
When I try to create ceiling or floor after selecting walls the command
does not exit.It always requesting to select a wall.
That is right.
If you are having trouble exiting the command, I would suggest you watch a couple tutorialS to get you rolling but you will probably need some formal training. Revit is not easy.
Edited by RobDraw
That is right.
Yes Stilling I am learning. The ceiling problem solved. The problem was I have not selected correct ceiling type & correct offset distance from the floor.
Now I am trying to draw floors. Thanks for your advice.
