Results 1 to 8 of 8
Thread: Help!
    Forum Newbie
    Civil 3D 2011
    Jul 2015
    4
    Default Help!
    So I was working on a cad sheet with an xref.
    Basically the xref exploded by itself and copied all the lines on to the actual drawing. There are bad linetype errors everywhere, and I cant open the file without it crashing on startup at the regenerating model phase.
    If i xref the drawing into a new dwg all the work i had done is there and is fine and dandy... so If anyone has any suggestions on how to proceed I am all ears.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I've never heard of that happening by itself.
    Unfortunately, you will have to somehow rebuild the file.
    Drafting is a breeze.
    Forum Newbie
    Civil 3D 2011
    Jul 2015
    4
    I was literally just annotating in a viewport, CAD crashed and it wouldnt open back up. I changed my profile from civil to Autocad in order to open it back up. It worked but I had every single line of my Xref in my sheet file on top of my xref. I tried to go about deleting (overkill, purge, and evetually manually) but it crashed again and now it wont open at all.
    But if I xref into a new drawing its all there.
    we have a BID set going out on monday dont really want to have to rebuild the whole thing!
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Would you rather redraw it?
    Since you have everything, utilize copy/paste to get the usable stuff into a fresh file.
  5. #5
    Forum Newbie
    Civil 3D 2011
    Jul 2015
    4
    just happened again on a different file.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Sorry about that.
    What were you doing when it happened?
    I have a vague memory of having this happen long ago. I think it was related to improperly converting incoming files that were created with newer versions or possibly a network latency issue.
    Another possibilty is that it a Civil issue and someone has come across it before. You may want to post in the C3D forum.
  7. #7
    Forum Newbie
    Civil 3D 2011
    Jul 2015
    4
    I opened a new file to check a Xref path to a title block since Im rebuidling the sheet. Was working fine yesterday, today, crazy explosion of xref lines...
    I am guessing it has something to do with file creation of new versions. I have the oldest version in the office.
    Did you find anything that worked?
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Nothing I haven't mentioned already.
Tags for this Thread
