Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member vanowm's Avatar
    vanowm's Computer Details
    Windows 7 SP1 x86/x64
    AutoCAD 2002
    Feb 2015
    124
    Question Arc with START, END, CENTER points?
    Hello.
    I'm using Autocad 2000i/2002 and looking for a way to draw an arc by using this order of points:
    1. START
    2. END
    3. CENTER (bulge)
    The available START END DIRECTION version is very close to what I'm looking for, except it doesn't allow me snap the center arch to an object, because the arc doesn't "tide up" to the cursor.
    I think 3-point circle closer to what I'm looking for then any available built-in versions of arc.
    Any ideas? Thank you.
    AutoCAD 2002 / R13
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,406
    Are you trying to drag the radius to something that looks good ? Just do a standard pick 3 pts Start mid end then click centre grip and move radius changes.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    What does "tide up" mean in this context?
    Drafting is a breeze.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Perhaps you could define your "technical" terms with the aid of some diagrams.
    We may know how to help you, but are presently baffled by your description.
    As I read your request, I would ask are your points geometrically compatible? The Centre of an arc lies on the perpendicular bisector of the Start and End points. But there again, I may not have grasped your meaning.
  5. #5
    Super Member Commandobill's Avatar
    AutoCAD 2014
    Oct 2008
    Raleigh, NC
    538
    Polyline arc, or normal arc?
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
  6. #6
    AutoCAD 2002
    Feb 2015
    124
    Quote Originally Posted by eldon View Post
    Quote Originally Posted by RobDraw View Post
    What I meant was the preview of the arc is "attached" to the cursor, unlike to an arbitrary line as in
    Code:
    (command "_arc" pause "_e" pause "_d")
    What I'm looking for is similar to Lee Mac 3-point circle
    So I guess "center" wasn't a proper word for it, perhaps bulge is more appropriate?
    Quote Originally Posted by Commandobill View Post
    Doesn't matter I guess.
    AutoCAD 2002 / R13
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,406
    Using a program you can do dynamic stuff like dragging a circle, I think you need to post an exact image of what it is you want it does not matter if you draw multiple arcs.
  8. #8
    AutoCAD 2002
    Feb 2015
    124
    Ok, draw an arc, now click on it and grab the middle grip, start dragging it around - that is exactly what I'm looking for during the initial creation of an arc after start and end points are set.
    Hopefully this is clear now
    AutoCAD 2002 / R13
  9. #9
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,406
    Why can you not do that now using MID and MOVE I think we are still missing something. I used copy for the image the line implies the copy direction but its still out of the box methods. Its a case of putting together a lisp that makes the arc and then uses the mid point as snap point can be done is this what your trying to do just remove the couple of manual steps. Please let us know.
  10. #10
    AutoCAD 2002
    Feb 2015
    124
    No, I'm not trying move the entire arc. In my last example clicking on the arc is necessary to bring up the grips, the grip in the middle you'd use to drag around to change shape of the arc.
    So, yes, creating a temporary arc after user submitted start and end points and then use stretch on the middle of the arc for the third point would work, except my lisp knowledge is limited to achieve that, that's why I asked if such solution already available...
    AutoCAD 2002 / R13
  1. Reverse start and end points of a line
    By byk3bep in forum AutoCAD Beginners' Area
    Last Post: 21st Jul 2015, 01:28 pm
  2. Replies: 13
    Last Post: 14th Nov 2011, 02:46 pm
  3. Start and End points of a TEXT
    By Sweety in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Sep 2010, 01:08 pm
  4. start and end points acaddimrotated objects
    By erdurmaz in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2009, 04:31 pm
  5. Arc - Start Center Angle
    By GREG in forum AutoCAD Beginners' Area
    Last Post: 10th Sep 2007, 02:41 pm
