Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Default Problem with macro for creating several dimension styles
    Hello everybody,
    I've created a macro for creating different dimension styles for different scales. We are using these dimension styles in our company. It works well if I use it in a new, empty drawing.
    But if I use it in an excisting drawing with a dimension style with the same name, I have got a problem.....
    I'll see this in the command line;
    "Enter name for new dimension style or [?]: "scale 20"
    That name is already in use, redefine it? <N>:_dimclrd
    Invalid option keyword.
    That name is already in use, redefine it? <N>:"
    "_dimclrd" should be the next command in the macro, but because "scale 20" is already in use, I need to do some other commands first.
    AutoCad stops with this macro at this point. If the first dimension style, which the macro should be create, already in use, the other dimension styles shall not be create.
    Is there a possibility/ sollution to change my macro so he creates every dimension style what he supposed to do? Also if one or more dimension styles already excist?
    The reason why; if you delete a dimension style because you think; "I don't need him any more." But you're wrong. Or somebody else goes further with the drawing and needs to draw something with another scale.
    You need to copy the 'wanted' dimension style from another (new/ excisting) drawing.
    Could somebody help me?
    This is the whole macro;
    Code:
    ^C^C_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;"";_dimldrblk;"";_dimasz;2;_dimcen;0;-style;;iso.shx;a;;;0;;;;;no;_dimtxsty;standard;_Dimclrt;2;_dimtfill;1;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;1;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;"scale 1";_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;"";_dimldrblk;"";_dimasz;2;_dimcen;0;-style;;iso.shx;a;;;0;;;;;no;_dimtxsty;standard;_Dimclrt;2;_dimtfill;1;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;2;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;"scale 2";_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;"";_dimldrblk;"";_dimasz;2;_dimcen;0;-style;;iso.shx;a;;;0;;;;;no;_dimtxsty;standard;_Dimclrt;2;_dimtfill;1;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;10;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;"scale 10";_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;"";_dimldrblk;"";_dimasz;2;_dimcen;0;-style;;iso.shx;a;;;0;;;;;no;_dimtxsty;standard;_Dimclrt;2;_dimtfill;1;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;20;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;"scale 20";_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;"";_dimldrblk;"";_dimasz;2;_dimcen;0;-style;;iso.shx;a;;;0;;;;;no;_dimtxsty;standard;_Dimclrt;2;_dimtfill;1;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;50;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;"scale 50";_dimclrd;1;dimltype;continuous;_dimlwd;-1;_dimdle;1.25;_dimdli;1.25;_dimclre;1;_dimltex1;continuous;_dimltex2;continuous;_dimlwe;-1;_dimexe;1.25;_dimexo;1.25;_dimblk;"";_dimldrblk;"";_dimasz;2;_dimcen;0;-style;;iso.shx;a;;;0;;;;;no;_dimtxsty;standard;_Dimclrt;2;_dimtfill;1;_dimtxt;1.8;_dimtad;1;_dimgap;1;_dimtoh;off;_dimtih;off;_dimtmove;0;_dimscale;100;_dimdec;0;_dimzin;0;_dimtolj;0;_dimse1;off;_dimse2;off;_dimrnd;5;_dimtofl;on;-dimstyle;s;"scale 100";
    Thanks
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    It has to be mentioned that annotative dimensions are very useful in eliminating the need for having different dimension styles just for different scales.
    Drafting is a breeze.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,025
    I would not do a macro that long rather convert it to a lisp then you can do a SEARCH for dim style existing and create a new one or overwrite the old one. ^c^c(load "checkdims") thats my macro. Have a look for a entmake dim style.
    Code:
    (setq  doc (vla-get-activedocument (vlax-get-acad-object))) ; open database
    (setq dstyle (vla-get-dimstyles doc))
    (vlax-for sty dstyle
    (princ (vla-get-name sty)) ; put a make dim style here using a if
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    Or create all the dimstyles and add to the drawing template.
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,025
    Yeah SLW210 much easier to remove than add.
    Or
    Make a dwg with all dimstyles using 1 dim, then just copy and paste.
  6. #6
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    The problem is that we have to change all the dimension styles. My company wants that every dimension style used in a drawing is a dimension with a closed filled arrow. At this moment we use dimension styles with an oblique.
    These "oblique" dimension are having the same name like the "closed filled" dimension.
    If I copy the new dimlinear from the one to the other drawing, with the old dimension styles, the new dimlinear is changing to the old one.
  7. #7
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,089
    Just add
    Code:
    ;yes
    after each style name, if the style exists it will be redefined, if it doesn't exist the "yes" will return an unknown command error, but the macro will continue either creating new styles or redefining existing ones.
    By the way the only thing that appears to change between styles is the _dimscale value, so after the first time the other variables are set there is no need to keep repeating them, which will cut your macro size down considerably, or at least make it easier to add extra styles in the future.
    EDIT just to be clear
    Code:
    should become
    Code:
    -dimstyle;s;"scale 1";yes;
  8. #8
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,025
    Now that you have narrowed it down to whats required and you have Autocad you should be able to do a simple search through all existing dim styles and change to closed arrow it will mean a little bit more on the sample code I posted previously, any one else ? jump in.
    So change DIMSAH, DIMBLK1 & 2 need to do some testing. Tharwat has some code that is close.
  9. #9
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    744
    Quote Originally Posted by RobDraw View Post
    I can remember having about 20 dim styles 20 years ago in r12, Annotative dimensions really simplified things. I now have 3 Annotative dim styles with Angular child styles in my templates.
  10. #10
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Quote Originally Posted by steven-g View Post
    Just add
    Code:
    ;yes
    Code:
    should become
    Code:
    Thank you very much Steven-G!
    How easy it can be....
  1. Problem with macro for creating several dimensional styles
    By Sandervp in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 27th Mar 2015, 12:00 pm
  2. creating styles
    By mfurches in forum Autodesk Inventor
    Last Post: 30th Nov 2012, 12:10 am
  3. VBA - Dimension Styles
    By wannabe in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2008, 06:18 pm
  4. Dimension Styles
    By rush02112 in forum Autodesk Inventor
    Last Post: 16th Jun 2007, 10:25 pm
  5. Dimension Styles
    By JaketheMan in forum AutoCAD General
    Last Post: 15th May 2007, 11:43 pm
Tags for this Thread
