Hatch Tool Pallette not working
Heather_H
We have 4 drafters using AutoCAD LT 2016, 1 using AutoCAD Mechanical 2016, and 1 using AutoCAD Mechanical 2012. I have created a Hatch tool palette from our 'source' drawing (we have several tool pallettes from this file).
The LT users are able to import the Tool Pallette and use the hatches with no problem.
The Hatches do not work at all in the 2016 Mechanical (Mechanical or Vanilla Profile). (Hatch file pattern not found)
They do work in the Mechanical for 2012, but not in the Vanilla for 2012 (same message).
We have cross-referenced pathing and locations.
Is there something I am missing?
Thank You in advance for your help!
  • 2 weeks later...
Is the pattern defined in the user's acad.pat file or in a separate *.pat file? The pattern will need to be defined in whatever *.pat file you are trying to pull the hatch from.
You can find it using (findfile "acad.pat")
  • 4 weeks later...
This sentence is so I can post "+1" because "+1" is too short.
This sentence is so I can post "+2" because "+1" is too few. :beer:
Edited by Dadgad
  • 3 weeks later...
