bleeargh Posted July 21, 2015 Share Posted July 21, 2015 My text window on autocad 2016 keeps going behind the autocad display. I need to minimize autocad to see my text window results. For example, the result after a "list" command. What is the toggle to get the window to show up in front like it's suppose to? Quote Link to comment Share on other sites More sharing options...
dtkell Posted July 21, 2015 Share Posted July 21, 2015 Alt+Tab will cycle through open windows switching focus to the one chosen. Quote Link to comment Share on other sites More sharing options...
bleeargh Posted July 21, 2015 Author Share Posted July 21, 2015 Yes. But I've never had to do that before. The autocad default is to have the autocad text window open up in front, not behind the work space. I can't find the simple command toggle that will make the text window behave the way it's default is. Quote Link to comment Share on other sites More sharing options...
rkent Posted July 21, 2015 Share Posted July 21, 2015 You are right in that it should show on top. You can set up a shortcut to use (textscr) to force it to show. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 21, 2015 Share Posted July 21, 2015 Is AutoCAD maximized and not just sized to fit screen? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 22, 2015 Share Posted July 22, 2015 The command line can be increased by say 1 line and this allows you see info when you do a list etc. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 22, 2015 Share Posted July 22, 2015 Are you using more than one monitor? Either something is activating the AutoCAD screen and bringing it to the front or I would venture it is an AutoCAD/Windows bug. Have you checked task manager to see what processes are running? F2 a couple more times should bring it to the front again. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted July 22, 2015 Share Posted July 22, 2015 I have various/random issues with the text screen all the time, and have since probably R2013. Sometimes F2 will open the text window and it will immediately disappear, so I just can't get to it at all, while other times is will display as designed. Sometimes when it does display correctly, I can't get rid if it by clicking the "X". I just have to click in the AutoCAD editor area to make the editor "come to the top" (so the Text Windows stays in the Windows task bar as an open window). I'm running 3 monitors on a Quadro K2000 with nView disabled. Was previously running 2 monitors with same issues. Quote Link to comment Share on other sites More sharing options...
ayethzerothree Posted September 2, 2015 Share Posted September 2, 2015 if my understanding is correct, typing a COMMANDLINEHIDE means the text window will close and typing again COMMANDLINE will open the text window. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 2, 2015 Share Posted September 2, 2015 if my understanding is correct, typing a COMMANDLINEHIDE means the text window will close and typing again COMMANDLINE will open the text window. The command line and the text window are two distinctly different entities. CTRL+9 is used to hide/unhide the command line while F2 opens/closes the text window. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 2, 2015 Share Posted September 2, 2015 For those not already aware, in newer versions OOTB, F2 merely expands the 'enhanced' Command Line, whereas Ctrl+F2 opens the 'classic' Text Window. The latter can be made default by editing the Shortcut Key assigned within CUI Editor... Under ACAD CUIx (Partial, for Verticals), Keyboard Shortcuts, Shortcut Keys, Text Window (the list is not alphabetical), change "Access" Property from "CTRL+F2" to just "F2." Cheers Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 2, 2015 Share Posted September 2, 2015 Another example of a wasted feature. AutoDesk should concentrate on more important things. We don't need to smear more lipstick on the pig. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 2, 2015 Share Posted September 2, 2015 For those not already aware, in newer versions OOTB, F2 merely expands the 'enhanced' Command Line, whereas Ctrl+F2 opens the 'classic' Text Window. The latter can be made default by editing the Shortcut Key assigned within CUI Editor... Under ACAD CUIx (Partial, for Verticals), Keyboard Shortcuts, Shortcut Keys, Text Window (the list is not alphabetical), change "Access" Property from "CTRL+F2" to just "F2." Cheers In AutoCad 2015, F2 expands the command line only if the command line is not docked. If the command line is docked, F2 opens the traditional text window without any retro-customization. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 2, 2015 Share Posted September 2, 2015 In AutoCad 2015, F2 expands the command line only if the command line is not docked. If the command line is docked, F2 opens the traditional text window without any retro-customization. Perhaps it's functioned that way since being introduced - I haven't docked the command line since learning how to undock it. Quote Link to comment Share on other sites More sharing options...
bleeargh Posted December 15, 2015 Author Share Posted December 15, 2015 I should have responded to you guys and let you know what fixed this. I just had it happen again and I had to go back to this post to remind myself of the fix. It was rkent that suggested the textscr command at the command line that always brings it back to the front. Why it gets sent to the back is still a mystery. F2 does not bring it to the front. It kind of gets stuck behind the Autocad main display and nothing brings it to the front except the textscr command. After applying the command, the F2 function works and everything goes back to normal. Thanks rkent! Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 16, 2015 Share Posted December 16, 2015 That's funny. I just installed 2016 LT today at work, and now the F2 thing is happening to me again, right out of the box (er, download) even with the command line docked and locked. I've only had it in for about an hour, no time to mess around yet. I still have to run the service packs. I hear there is a SP2 for 2016 LT already, can't look until morning. I am also moving my direct supervisor from 2006 LT to 2016 LT. This should be fun. He's been THE drafting department here for 19 years and I have not been here for a month yet. Quote Link to comment Share on other sites More sharing options...
Art I factory Posted September 13, 2020 Share Posted September 13, 2020 On 7/21/2015 at 11:13 PM, bleeargh said: My text window on autocad 2016 keeps going behind the autocad display. I need to minimize autocad to see my text window results. For example, the result after a "list" command. What is the toggle to get the window to show up in front like it's suppose to? Just go to the windows task bar, right click and open Task manager, there you can see “Autocad text window” right click on that and click “bring to front” and done. Every time you press F2 or ctrl F2 the window will pop infront. Quote Link to comment Share on other sites More sharing options...
