CalypsoArt Posted July 23, 2015 Share Posted July 23, 2015 I'm new to groups in AC. I've made a few using the "group" command. However, when wanting to edit/add objects, I'm asked for the "name of the group." When making the groups using "group" I'm never asked to give it a name. If I don't name the group, what is it called, and where can I find this info? where is the list of groups in a drawing? Quote Link to comment Share on other sites More sharing options...
tombu Posted July 23, 2015 Share Posted July 23, 2015 _classicgroup at the command line or Group Manager on the Ribbon. Check Include Unnamed in the dialog box. The Unnamed ones start with an asterisk. Quote Link to comment Share on other sites More sharing options...
CalypsoArt Posted July 23, 2015 Author Share Posted July 23, 2015 _classicgroup at the command line or Group Manager on the Ribbon. Check Include Unnamed in the dialog box. The Unnamed ones start with an asterisk. Thanks. However, when the dialog box opens, I still can't figure out which of the asterix-ed groups is the one I want. It seems that one should be able to select a group and then apply the options to the selected group. As when opening a block. I am using AC2012. I have it set up as the "classic" UI like all my previous versions. The Ribbon just doesn't work for me and how I work. I realize that by not using the ribbon I am missing some options. Quote Link to comment Share on other sites More sharing options...
rkent Posted July 23, 2015 Share Posted July 23, 2015 In the Group dialog there is a button Find Name, pick that, pick the group, it will give you the name, proceed from there. Quote Link to comment Share on other sites More sharing options...
tombu Posted July 23, 2015 Share Posted July 23, 2015 You can also pick a group and list it. Look for Group = It's the same for each entity. Quote Link to comment Share on other sites More sharing options...
