Results 1 to 6 of 6
    Junior Member
    AutoCAD 2000
    Apr 2015
    18
    Default 3d transform to 3 view
    how you transform from 3d drawing in autocad 2000 to 3 view drawing?
    Junior Member hlammerts's Avatar
    AutoCAD 2014
    Sep 2014
    22
    One possibilty.
    View front, side and top as viewports with some dims.
    Senior Member zaphod's Avatar
    AutoCAD 2017
    Sep 2013
    Houston, TX
    175
    "base view" on newer versions, I don't know if the command "flatshot" works in version 2000
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Does AutoCAD 2000 have the following commands:
    1) SolProf
    2) SolView/SolDraw
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Yes it does ReMark.
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by SLW210 View Post
    Yes it does ReMark.
    Wow, that blows my mind, that SOLPROF has been around for so long.
    I personally like using SOLPROF, but the resulting images are not associative, which is a tradeoff.
    If you use SOLPROF, create as many copies of your 3D Model, as you want to show views, then position them relative to the existing model, meaning you will need to 3DRotate the new ones into their proper positions in modelspace. It is a good idea at this point to delete anything you do not want to show in any particular view.
    Then start the SOLPROF command and read and follow the commandline prompts carefully.
    A couple of blocks will be created, one of which will show the visible lines, and the other (if you selected the option), will display the hidden lines.
    In my own work, I would then move both of the blocks out a know distance in a different direction, and move the 3D Models from which they were generated out of the way (this is actually quite easily done using the LAYISO & UNLAYISO commands instead of moving the blocks). I then explode both of the blocks at the same time, and run OVERKILL on them (you won't be able to do that in 2000), because it will clear out a lot of duplicated and redundant lines. I then select everything from my Hidden lines block and change the layer in my quick properties to Hidden Steel, so the line work will assume the layer color. I put the Visible lines on my Steel layer, then I move both sets of lines back by the known distances and in the opposite direction from which I earler displaced them. Then they will look rather like in the screenshot. . I haven't marked my hole centers in the screenshot, because SOLPROF won't do that for you, but Lee Mac has a great lisp that will, all in one go.
    http://www.lee-mac.com/associativecenterlines.html
    Thanks Lee!
    That should get you headed in a right direction for starters.
    Yes, it is not Associative, but it is pretty darn fast, by pre Viewbase (2012) standards.
  1. transform list in selection set
    By transcad in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd May 2012, 02:11 pm
  2. How can I transform this into a solid or region
    By -TJ in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Jun 2008, 03:12 pm
  3. Transform Coordinates
    By Nestor in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jun 2008, 09:22 am
  4. Transform?
    By cadfly in forum AutoCAD General
    Last Post: 24th Apr 2008, 07:26 pm
  5. transform a Spline in a polyline.....
    By mfalcaof in forum AutoCAD General
    Last Post: 12th Jul 2006, 12:38 am
