Da Ballz Posted July 27, 2015 Share Posted July 27, 2015 (edited) Hey gang, I have legacy drawings where the revision information lies in separate blocks, and I want to use a lisp to write the attribute values of those blocks to new title blocks with their own attributes. The legacy block in question is named REVOLD. There are as many as a dozen copies of it in a given drawing, each with different attribute values for the following tags: X (Revision number) XX/XX/XX (Date) XXX (Done by) X (Revision description) XX (Number associated with work order) I know, it's atrocious. I need to map the attribute values of all instances of REVOLD to the following title blocks (depending on which one is in the drawing, also you can assume the new title block will already be in the legacy drawing because I will run that script before this one): Drawing_Sheet_1 Drawing_Sheet_2 Drawing_Sheet_3 The attributes of the new title blocks are: REV1 DATE1 APP1 DESC1 DCR1 REV2 DATE2 APP2 DESC2 DCR2 This pattern repeats up to 6 (but I'm only concerned with the first 4 for this entire problem) To make things simple, I will only care about the last four (or four newest) REVOLD revisions. If there are more, I'll just discard them. The attributes map one for one. For example: REV1 = X; DATE1 = XX/XX/XX, ect. I will need to put the REVOLD attributes in date order so the earliest of the TOP 4 instances of REVOLD becomes REV1, the next instance REV2, and so on. I hope that makes sense, I'll clarify more as need be. Edited July 27, 2015 by Da Ballz fix logic error Quote Link to comment Share on other sites More sharing options...
pBe Posted July 27, 2015 Share Posted July 27, 2015 Question (s): If there are 4 revisions there are 4 REVOLD blocks? After sorting pass the values to the NEW revision box on the new title block [ already inserted ] After passing the value delete the REVOLD blocks? What are the TAG names on the REVOLD blocks? What is the format of the date? mm/dd/yy or dd/mm/yy? Thoughts: IF the REVOLD revisions are in a vertical position no need to sort by date. Having said that, "earliest of the TOP 4" means the first four from the bottom going up? "I will only care about the last four (or four newest) REVOLD revisions." IMO its easier to describe the problem via drawing sample. [ Delete ALL confidential information / or even a drawing with a similar condition showing before and after ] Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 27, 2015 Author Share Posted July 27, 2015 Answers: 1. There could be more than 4 revisions, but there is only so much space in the new title blocks. Drawing_Sheet_1 can hold 6 revisions Drawing_Sheet_2 can hold 4 Drawing_Sheet_3 can hold 4 2. Correct 3. I specified the REVOLD attribute tag names in my initial post. That's what all of those horrific X's are about. 4. The REVOLD date format is MM/DD/YY; the date format for the new title blocks is DD-MMM-YY (example: 29-DEC-15) Thoughts Answers: Yes. the REVOLD blocks are stacked on top of each other. The top one is the latest revision. You're right, I contradicted myself. What I need are the latest 4 REVOLD revisions, or in terms of date, the most recent 4 revisions. I will scrub a drawing and attach as soon as I can...good point. Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 27, 2015 Author Share Posted July 27, 2015 pBe This is essentially what I'm trying to fix over hundreds of drawings. I need to map all of the REVOLD block's attribute values to the new title block with a lisp. Otherwise I have to basically hand jam each revision one by one, which will take forever considering there are literally hundreds of drawings. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 28, 2015 Share Posted July 28, 2015 Couple of questions and some answers. Is their only 1 layout sheet per dwg ? I would probably make a list of the information depending on its length determines last 4 or less etc then update new block. Its not off the shelf but its doable just need some time. Others step in ! Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 28, 2015 Author Share Posted July 28, 2015 Bigal thank you. Yes, there is only one title block per drawing, in paper space, on the default Layout1 tab. I think a list might work fairly easily because although the tag names are different, the old attributes correspond with the new attributes perfectly. So the attribute values should transfer cleanly. I'm just not sure about how to map them in the correct order. I was originally thinking by date. You can see in the drawing that the oldest revision is on the bottom and they are stacked on top of each other. Quote Link to comment Share on other sites More sharing options...
pBe Posted July 28, 2015 Share Posted July 28, 2015 (edited) pBeThis is essentially what I'm trying to fix over hundreds of drawings. On your sample drawing, Add Revision 5,6 & 7 from REVOLD after 4? or remove 4 entirely? Before and after remember? AND after transferring the data from OLD to NEW , update the REV tag as well correct? Edited July 28, 2015 by pBe Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 28, 2015 Author Share Posted July 28, 2015 pBe, yes you would add those revisions in order above Rev 4. But I only showed Rev 4 as a sample of how the new title block revisions should look like. In reality, the new title block will be blank, and you will start plugging in the first REVOLD revision at REV1, DESC1, ect, then add the rest in order until the new title block revisions are full or all the REVOLD revisions are transferred. Yes, update the REV tag to the match the latest (highest) revision. Quote Link to comment Share on other sites More sharing options...
pBe Posted July 28, 2015 Share Posted July 28, 2015 (edited) So its is normally blank? Do I need to add an option on the program if there are values already on the Titleblock ? and "bump" it down in case the revision boxes are full? How often does that happen? Don't give up now, you are almost there. Edited July 28, 2015 by pBe Quote Link to comment Share on other sites More sharing options...
pBe Posted July 28, 2015 Share Posted July 28, 2015 (edited) This is what i have so far. it would've been better if you post a reply now than later. [ today i had time to kill so here goes.. Conditions: 1 layout tab 1 titleblock I threw in the option i mentioned on my previous posts regarding existing values on revision box.... Hope this helps UpdateRevisionBox.LSP Edited July 29, 2015 by pBe Atatched the lisp file instead of code tags Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 28, 2015 Author Share Posted July 28, 2015 I already have a script to bump down revisions, great question though. What I plan on doing is throwing this code into my existing macro. This is the last piece of the puzzle...I think Sorry about not getting back earlier, I was asleep. We are probably on opposite sides of the globe. Your code...wow! I will mess with it today as time permits and get back to you. Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 29, 2015 Author Share Posted July 29, 2015 pBe Correct me if I'm wrong here. I notice that you define local functions in the main function. But then, after defun five, I can't tell what happens. Is five one huge function? Or are there function definitions missing? Also, I'm getting the error: malformed list on input. Upon debugging, I can't seem to find an obvious problem. I'll go through it line by line and see what I may have missed. Quote Link to comment Share on other sites More sharing options...
pBe Posted July 29, 2015 Share Posted July 29, 2015 But then, after defun five, I can't tell what happens. Is five one huge function? Or are there function definitions missing? Five is just a sub to group a list into sets of five elements. the main function starts at (and (setq RevoldColl nil ss (ssget "_X" ..... Also, I'm getting the error: malformed list on input. Upon debugging, I can't seem to find an obvious problem. I took out the code tags from my previous post and attached the lisp file instead. That way WYSIWYG.. no copy and paste on notepad . I'll go through it line by line and see what I may have missed. Make it so. Quote Link to comment Share on other sites More sharing options...
Da Ballz Posted July 29, 2015 Author Share Posted July 29, 2015 All I have to say is wow pBe. It works like a charm my friend. How long have you been programming in AutoLISP? Quote Link to comment Share on other sites More sharing options...
pBe Posted July 29, 2015 Share Posted July 29, 2015 All I have to say is wow pBe.... Good for you Da Ballz. Hope you'll learn from it. ...How long have you been programming in AutoLISP? Too long as a mater of fact ... About around 2009 when I started fooling around [ really focusing that is ] with Visual and Vanilla lisp as well. pBe Quote Link to comment Share on other sites More sharing options...
