BSracer Posted July 28, 2015 Share Posted July 28, 2015 I have drawn a barrel profile and would like to subtract the bore with rifling. I have the P-line of a cross sectional of the rifling. Can I sweep the center line of the bore and rotate it in the path? I thought sweep would let you rotate in the path. Helix won't let me rotate in a straight line. Quote Link to comment Share on other sites More sharing options...
BSracer Posted July 28, 2015 Author Share Posted July 28, 2015 I think I got it. I had to limit the sweep to the length of 360 degrees. Then I copied end to end. Looks good but has a line where I Union the two pieces together. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 29, 2015 Share Posted July 29, 2015 Welcome to CADTutor. Good work, gald you were able to figure it out. On questions like this one, it is always a good idea to attach a screenshot, at the least, or better yet a .dwg file, as it makes it much easier to get quick and appropriate help. Lots of members may be loathe to engage in a protracted multi post thread, but willing to open a drawing and take a quick look on the fly. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 29, 2015 Share Posted July 29, 2015 Welcome to CADTutor! If there is a line at the UNION, you probably do not have a good alignment. Post your .dwg and someone will take a look. Quote Link to comment Share on other sites More sharing options...
