No objects in Model space, But View ports has dwg views
RRS1987
Hi Every one,
Hopes, All are fine.
I have received one vendor dwg, I can see drawing in paper space, but there is nothing in model space. And also I drawn one circle in model space to find the dwg location, through paper space view ports. After I returned to model space, there is only one circle, which I drawn earlier. So how can I find the dwg in model space, where i have to make changes. Also I can see some block reference, while I am doing Ctrl+A in model space
Thank you very much,,
thanks for your earliest reply,
File size 2.5MB, so I couldn't able to upload my dwg. Is there any other way to upload my dwg?
Once again thanks.
Check that your layer filter is set to ALL LAYERS so you might see more of what is going on. Make sure the objects are not actually drawn in paperspace.
do a zoom extents in model space which is Z then E enter. Erase the stuff you drew before. Could be the view in model space is zoomed way out or it is panned off screen.
