Results 1 to 6 of 6
    Full Member Behemothrex's Avatar
    Behemothrex's Computer Details
    Windows 10 64 bit
    ASUSTeK COMPUTER INC. P8Z77-V PRO/THUNDERBOLT
    Intel Core i7 3770K @ 3.50GHz
    Corsair Vengeance 32.0 GB Dual-Channel DDR3 @ 668MHz
    Dual SLI Gigabyte GeForce GTX 670's
    OP system and Autocad only - Crucial 128GB SATA III SSD
    Western Digital Black 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
    LG W2353V 23"
    AutoCAD 2015
    Jul 2012
    Kentucky
    55
    Embarrassed One Point Perspective
    Hey guys,
    Okay I am a bit confused, thought I had this down, but the more I look into it the more confused I get. The book I am using has about 4 paragraphs on how to do this, and it leaves out some major points, or at least I think it does.
    I need to make a one point perspective of a room, and I have some measurements, and the elevations. I can't just use the standard perspective method as I have actual measurements to use.
    The trouble I am having is how to set this up so I can transfer the measurements. The example in the book seems straight forward, except they don't say how to space things in the elevation view or how to find the distance between the plan view and the perspective view.
    I tried to reproduce the plan view but I found that several measurements are missing, so there must be a different way to do it without the measurements.
    So I will enclose the example from the book and the reference drawing I was given.
    A starting point would be greatly appreciated.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    1. The elevation is the right side view of the plan, so the spacing will be the same as that shown in the plan view.
    2. This is arbitrary. You have the SP which established the width of objects so it doesn't matter how far down you project the horizontal lines off of the picture plane. When drawing on the board we were limited to the sheet of paper. With CAD that limitation kind of goes away, so if you want to work further away you can.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Windows 10 64 bit
    LG W2353V 23"
    AutoCAD 2015
    Jul 2012
    Kentucky
    55
    Thanks rkent,
    What confused me about the spacing of the elevation view was in the example the book shows it goes A, B, C, but in the plan view its A, C, B which seems wrong, if you are going left to right.
    Okay will try to reconfigure my elevations and then project to the perspective view and see how that goes.
    Bah, this is going nowhere LOL. As there doesn't appear to be any easy way to find the distance between the cabinets. And how do I establish the station point in the perspective view, do you just pick a spot? Gah my brain is exploding, going to take a breather I think.
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    The elevation is looking front to back so the order of the objects makes sense.
  5. #5
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    The station point isn't a fixed, always use this point rule, it is as you say "just pick a point" but it does effect how the final perspective looks and is often based on a point using the cone of vision shown on your example, this usually means that you end up with a nicely proportioned drawing. The "picture plane" is also a pick a place decision, and will only make a difference to the size of the final drawing, so you should draw a line so that where it goes across the cone of vision the distance between where the lines cross each other is the size of your "paper".
  6. #6
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    364
    Your question 1 “…the spacing of things in the in the elevation view…” The spacing should be the same as the spacing of those things in the plan view.
    Your question 2 “… the distance between the plan view and the perspective view.” Dows not matter as you are projecting (vertically) the intersection of sight lines and their intersection with the picture plane.
    Set up both a plan and elevation view as in the sample drawing. Just having an elevation scale is not sufficient.
    The distance from the picture plane to the front of object A in the plan view should be the same in the elevation view.
    The location of the SP defines the degree of perspective. The closer it is to the Picture Plane the more pronounced (exaggerated) the perspective view. Move SP to infinity and you have a parallel projection. The distance from the SP to the PP should be the same in the plan and elevation views. As steven-g states, the location of the PP simply scales the perspective projection.
  1. 1 point perspective and 2 points perspective
    By BillyWonka in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jul 2015, 04:20 pm
  2. 2 Point Perspective
    By flaray in forum AutoCAD General
    Last Post: 26th Mar 2009, 12:43 pm
  3. 1 vs 2 point perspective
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th Jan 2007, 05:55 am
  4. 2 point perspective
    By gib65 in forum AutoCAD Beginners' Area
    Last Post: 22nd Jun 2006, 09:12 pm
