Murphy625 Posted August 5, 2015 Share Posted August 5, 2015 I am encountering some strange layer behavior I can't figure out. I have about 6 layers.. two of them are being problematic.. They keep turning themselves off or freezing without me telling them to do that. I'll turn them on, or unfreeze the layer(s), draw a bit, render some, switch views, then when I go to look at the drawing, the layers have either been turned off or frozen without me ever having opened the layer dialog box.. When I turn them back on, they stay for a bit.. rinse and repeat every couple minutes.. I'm just scratching my head on this one.. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 5, 2015 Share Posted August 5, 2015 Might you have inadvertently saved a New View with layer snapshot enabled? Quote Link to comment Share on other sites More sharing options...
Murphy625 Posted August 6, 2015 Author Share Posted August 6, 2015 Might you have inadvertently saved a New View with layer snapshot enabled? Wow.. you guys are freaking autocad guru's.. Yes, I saved a view.. I never new that it would modify the layers.. I just figured out how to turn it off.. retested, works good now. Thank you.. (I've been saying that a lot since I got this new version of acad!) Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 6, 2015 Share Posted August 6, 2015 (edited) Wow.. you guys are freaking autocad guru's.. Yes, I saved a view.. I never new that it would modify the layers.. I just figured out how to turn it off.. retested, works good now. Thank you.. (I've been saying that a lot since I got this new version of acad!) Sometimes we just get lucky, and it seems that way. You have the option when creating a new view, of disabling the layer snapshot function, which it sounds like, would be best for you. Glad to help. Typically when I am using this, it might be to create and save a view which I will use in a viewport, and this would represent another way to VP Freeze layers, and a particular perspective, and zoom value, as I tend to opt for the defined window option, instead of the current display. Should it be a particular perspective that I like, and might want to use for other drawings, then I would uncheck the layer snapshot. You can also elect to UPDATE LAYERS, when you are in a saved view, as shown on the right side of the screenshot. Edited August 6, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
Murphy625 Posted August 6, 2015 Author Share Posted August 6, 2015 Good to know.. thanks! Might come in handy one of these days when I'm working on a more complex model. Quote Link to comment Share on other sites More sharing options...
Organic Posted August 9, 2015 Share Posted August 9, 2015 I find this (layers randomly turning themselves off) a frequent occurrence. I have never found a solution. Quote Link to comment Share on other sites More sharing options...
cadredesign Posted March 2, 2016 Share Posted March 2, 2016 I tried updating the layers in Viewmanager and it DOES NOT WORK. I get the same behavior with layers randomly freezing! Quote Link to comment Share on other sites More sharing options...
