Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2012
    Aug 2015
    5
    Default A big letter "S" appears in paper space layout but it's not there in the model space.
    I'm working with a floor plan that was forwarded by a contractor. When I go to paper space in the layout tab, a big "S" appears in the middle of the floor plan but it is not there in the model space. How do I make the "S" disappear from my paper space layout? I'm using AutoCAD 2012 - the file I'm working with was created from a newer version that I had to "save down".
    AutoCAD 2013
    Nov 2011
    5,994
    Welcome to CADTutor.
    It sounds like the S was created in paperspace, not Modelspace.
    If you click on it to select it, you can likely learn a great deal about it from the Properties or Quick Properties.
    Report back to us if you are unable to select it, or if you are able to select it and need further assistance.
    Forum Newbie
    AutoCAD 2012
    Aug 2015
    5
    No, the "S" isn't in paperspace. I can't select it, only the viewport is selected. If I click inside of the viewport and it toggles to modelspace, then I can select the "S" - the entire floorplan is selected. I can open it in block editor but the "S" is not there, just as it's not there when I go to the model tab. But it is still there in the paperspace layout.
    Super Member Commandobill's Avatar
    AutoCAD 2014
    Oct 2008
    Raleigh, NC
    538
    Sounds like the S is perhaps part of a linetype which the scale changes in paperspace, or an annotative text style?
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
  5. #5
    AutoCAD 2013
    Nov 2011
    5,994
    Try using the NC (Nested Copy) command to create a copy of the S, and you will be able to get some information off the extracted copy.
    You will be able to figure out from the Properties of the copy, what sort of entity it is, whether or not it is annotative, text style, scale, layer, and such, which will help to determine how you should approach it.
  6. #6
    Forum Newbie
    AutoCAD 2012
    Aug 2015
    5
    I have found a resolution, though I have no idea about the why's and the how's of the resolution. I deleted the viewport from the paperspace layout tab, then created a new viewport and scaled it accordingly. The mysterious "S" did not appear in the new viewport.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    Can you post the drawing? All we need is the S to be there and behaving as you indicate.
  8. #8
    Forum Newbie
    AutoCAD 2012
    Aug 2015
    5
    Well, I thought I had a resolution. I saved the drawing, opened it back up, and the "S" is back.
  9. #9
    AutoCAD 2013
    Nov 2011
    5,994
    Have you tried the NESTED COPY approach?
  10. #10
    Forum Newbie
    AutoCAD 2012
    Aug 2015
    5
    I've got a resolution again, using the NESTED COPY approach. I had not been familiar with that command. I was able to click the properties of the copy and find the layer that it was on. I somehow missed this in my own search, but after turning that layer off within the viewport (and globally b/c I just don't need it), the big "S" disappeared. Thanks for the help! Much appreciated!
  1. Problem "Insert In Model Space" on Inventor 2014
    By PetrolAholic in forum Autodesk Inventor
    Last Post: 6th Jun 2013, 12:34 pm
  2. How do I make my paper space layout 36" x 72"
    By EdwardSheetmetalhand in forum AutoCAD Drawing Management & Output
    Last Post: 27th Nov 2010, 06:43 pm
  3. Drawing appears different in paper space than model space
    By dwelch in forum AutoCAD Beginners' Area
    Last Post: 19th Feb 2010, 12:35 pm
  4. model space <-> paper space in layout tabs
    By alijahed in forum AutoCAD General
    Last Post: 18th Mar 2009, 04:19 am
  5. Fill Mode only works in "Paper Space"...
    By XJHay in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jun 2007, 08:15 pm
Tags for this Thread
