Results 1 to 3 of 3
    Senior Member
    gbradley's Computer Details
    WIndows 7 64 Bit
    HP Z400
    24 Gig
    Invidia
    Inventor 2018
    Sep 2008
    So Cal
    122
    Default Punching a Hole in the side of a plate
    Is there a simple way to put a Hole in using something similar to the Placement "From Hole"?
    I tried to use Linear, but I don't have a straight edge, and when I select the center hole it automatically switches to Concentric.
    The way I end up doing it is sketching a circle and extruding it through, or placing a point and putting the hole on the point.
    Either way I have to create a sketch.
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    Sketch on the face first and then use a point dimensioned to the location you want. Then when you start the Hold command it will allow you to use the From Sketch option.
    Mark Flayler
    Application Engineer - Manufacturing Solutions Division
    Blog: http://blogs.rand.com/manufacturing/
    Partner Certified, Inventor Certified Expert
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    I'm quite an old school fan of placing holes with sketch points and never really used the hole placement tool if thou it has been around many years now.
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
  1. Punching pipe and rivet in Inventor library
    By Arnc in forum Autodesk Inventor
    Last Post: 21st Feb 2012, 06:28 am
  2. Replies: 0
    Last Post: 10th Sep 2010, 07:20 pm
  3. Replies: 8
    Last Post: 20th Mar 2010, 11:42 am
  4. 3D Model Side Plate of Spiral Problem
    By RODDY1 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Apr 2008, 05:01 pm
  5. Placing a hole on the side of a cylinder - Inventor
    By amirintisar in forum Tutorials & Tips'n'Tricks
    Last Post: 5th Mar 2006, 09:13 pm
