therock005 Posted August 13, 2015 Share Posted August 13, 2015 When i finalise my work I export a drawing to the pdf format. I just need opinions though as to what the best virtual printer service is, so that the pdf file has accurate information so the printed papers dimensions can be measures to the point Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 13, 2015 Share Posted August 13, 2015 Any decent ones do that. Precision is usually lost when printing the PDF. Improper plot settings, plotter not calibrated, humidity, etc. can all affect precision. Quote Link to comment Share on other sites More sharing options...
Pablo Ferral Posted August 13, 2015 Share Posted August 13, 2015 The Native DWGtoPDF drive is pretty good. Quote Link to comment Share on other sites More sharing options...
therock005 Posted August 13, 2015 Author Share Posted August 13, 2015 I hear bad things about the dwgpdf.pc3. RobDraw how certain are you that the pdf no matter how good the resulted file, will print worse than a dwg file Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 13, 2015 Share Posted August 13, 2015 The Native DWGtoPDF drive is pretty good. 1+ I'm a big fan of DWG To PDF, and the Autopublish mechanism. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 13, 2015 Share Posted August 13, 2015 The native .dwg to .pdf driver these days is excellent. Your profile says you are using 2007. I can't be sure if it had started improving at that point or not. Actually, I'm fairly certain that most PDFs created from decent print drivers can give you a paper print quality that is comparable to AutoCAD. Even some of the free ones are good enough. If you are looking for a free one, I've used CutePDF in the past with good results. The point I was trying to make is that where you are sending the print is more likely to underperform compared to the software, but you may be right about the one in AutoCAD 2007. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 13, 2015 Share Posted August 13, 2015 I can't be sure if it had started improving at that point or not. Correct; DWG to PDF prior to 2009 version (when PUBLISHCOLLATE sysvar, and Autopublish, etc. were introduced), was in fact pretty terrible. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 14, 2015 Share Posted August 14, 2015 2nd use cutepdf with old version as its a windows printer driver not a Autocad product and is windows version dependant. Quote Link to comment Share on other sites More sharing options...
